Home > Puma (Tdci) > Yeahhh I have variable front wipe washer intermittence
Page 3 of 8 <12345678>
dgardel
Italy
Bomber82 wrote:
Last week I was thinking about something like this while I was driving under rain!!!
dgardel I think you can do a big favour to italians Landers if you can report this tips on our forum!! Thumbs Up
Tomorrow I will ask to a VW dealers is this is available.
Thanks!! Bow down
Fatto!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #16983 21st Oct 2009 11:21am
CyberCharlie
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
[quote="Ads90"]Thanks for posting that - I would like to do the rear wiper mod, but sounds like it's the instructions for connecting to the pre-2002 rear wiper knob, but presumably it will work on the later push/push button?
Anyone know the connections, or if there is a relay that can be swapped (like the front wiper mod)?[/quote]
Hi guys,
just a quick "up" for this thread: anyone has managed to make intermittent the rear wiper of a Td5 or a Puma using the spare relay after the replacement with the VW one? The instuctions in the pdf file are clearly for the pre-2002.
From the wiring diagram of the Td5, there should be a relay so most likely just replacing it with the spare one should do the trick (proven that the connections feed the correct contacts on therelay)... problem is that i have no idea of where to go an look for the relay Big Cry
Thanks for your time Smile
Post #39270 28th Aug 2010 3:47pm
Lionel
Australia
Re: Yeahhh I have variable front wipe washer intermittence
dgardel wrote:
With A REAL PLUG & PLAY solution....
buy this click for ebay
Volskwagen code: 357 955 531 or 3B0 955 531
Bosch code: 0 986 335 058
Beru code: 0 900 301 082
To program is easy:
Push down on the w-w lever, have it wipe once, bring it up and wait until you need to wipe again,
then push it down.
It'll use the same wait interval! Very clever, but not obvious.
more info and more spare parts code here Selec wiki
Happy to improve our Puma
I know this is a Puma specific catagory, but I have just obtained one of these wiper relays for use in a TD5 Defender, and it does not appear to work correctly. Everything works as described EXCEPT that if one pushes in the stalk to wash the windscreen the wipers remain on, instead of turning off after 3 wipes. The only way to turn the wipers off is to turn off the ignition. After this, the only thing that will work is constant wipers at low or high speed. After leaving everything off for a few minutes, the intermittent will work again, but with the same problem as described.
I think I probably have a faulty relay (just my luck!), but I would like to hear from any TD5 owners who have used these relays successfully, just to ascertain this before I return it.
Any information would be appreciated.
Cheers,
Lionel
Post #43338 23rd Oct 2010 1:14am
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
Works just fine on mine. Suspect you have a duff relay... Dave
Green Goddess - 1998 Defender 110 300tdi
Post #43345 23rd Oct 2010 7:24am
Lionel
Australia
You're not wrong! Exchanged the relay, and now everything works as it should! Thanks for info.
Cheers,
Lionel
Post #43521 26th Oct 2010 3:17am
nosnibod
Thumbs Up Dave
Post #43523 26th Oct 2010 6:18am
BarneyRubble
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Where to get them
Just been quoted £55 each from my local Bosch retailer, and told none in UK stock. Big Cry
I don't like ebay, so any suggestions where else to get them? Barney
D4 - 2016 Graphite, Montalcino Red
Written Off - 2010 90 Hard Top, Stornoway Grey
Post #43775 28th Oct 2010 11:17am
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
Quite a few on ebay - look for the 99 in the picture.... My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #43806 28th Oct 2010 4:31pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Relay arrived today and works as described. Found it on eBay USA. $18 inc postage to UK. Still 2 left from this supplier if anyone interested : [url] http://cgi.ebay.com/ebaymotors/ws/eBayISAP...3574[/url]
Post #44125 2nd Nov 2010 6:40am
Amos
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Anyone got a link, to were they bought there's......?
Post #44129 2nd Nov 2010 8:17am
BarneyRubble
Got mine from ebay in the end - search for the VW code 357 955 531 - £12 ish + £2.50 postage.
Works great. Barney
Post #44146 2nd Nov 2010 11:01am
Amos
Got a Bosch one new...! Cheers
Just need my 90 to arrive now, lol...!
Post #44161 2nd Nov 2010 1:42pm
60North110
2007 Defender 110 Puma 2.4 CSW Java Black
Just got one off ebay, fitted today Thumbs Up
Brilliant ! Now can the Rear Wipe be made intermittent wipe too ? Very Happy
Post #44360 4th Nov 2010 10:59pm
SiWhite
Mine arrived this morning (the VW 99 relay) and it was fitted within 5 minutes!
In terms of bank-per-buck, this has to be one of the best mods you can do to a Landy.
Mine is fitted to a TD5, in case additional confirmation of suitability is required. My blog - www.anacreinhampshire.blogspot.co.uk
Post #44374 5th Nov 2010 10:21am
BarneyRubble
Have just modified the rear wiper to get variable intermit.
Easy mod - move 2 wires, add a 12v and ground connection and fit one link.
Biggest hassle is getting the connectors out of the existing relay base.
I'll post the wiring diagram when I have corrected it.
Works like the front - press the switch, let it wipe, switch it off, wait until you want it to wipe again, switch it on, and leave it - the wipers operate on intermit at the time you left between switching off and back on again. Barney
Post #45215 14th Nov 2010 1:04pm
