Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4786 |
Very soothing to my ocd 2002 90 Td5 Station Wagon
15th Jun 2018 10:54pm |
mine too Ray
15th Jun 2018 11:08pm |
16th Jun 2018 7:49am |
Now if only my budget could keep up with my ocd on the rest of the things that need doing Ray
16th Jun 2018 11:01am |
Started the Provent catch can fitting today, first was to drill out some flat bar to fit to the wing support bracket and give it a bit of paint.
Click image to enlarge Next bolt it all to the provent. Click image to enlarge Then bolt it back to the wing. Click image to enlarge Click image to enlarge I’ve already got all the pipes together but I’ll have to fit those tomorrow if it’s dry. Thanks for looking Ray My build thread http://www.defender2.net/forum/topic17615.html |
16th Jun 2018 8:11pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10801 |
Looks a nice and neat job Ray 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
17th Jun 2018 8:01pm |
Thank you should be nice and easy to get to when the filter needs changing too didn’t get round to fitting up the pipe work today though because Father’s Day is more work than a regular Sunday Ray
17th Jun 2018 9:19pm |
Keeper. Clayton. |
17th Jun 2018 9:28pm |
Still haven’t got around to finishing the provent but this turned up today.
Click image to enlarge A nice new centre box. We’re taking my parents on holiday with us this year so I decided to put a silencer back on in place of the straight through pipe to make it a bit quieter for them on the 7/8 hour drive to the ferry. I’m such a good son Ray My build thread http://www.defender2.net/forum/topic17615.html |
18th Jun 2018 10:12pm |
Castillo Member Since: 23 Nov 2012 Location: Tavastkyro Posts: 41 |
Do this middle a great difference in noise defender 110 td5 2006
19th Jun 2018 4:34am |
It’s a lot quieter than a straight through pipe Ray
19th Jun 2018 8:17am |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1763 |
An even better son would have done the relaxing Hull crossing so as not to punish them to a slog in a Defender
19th Jun 2018 4:35pm |
I’m not that nice Ray
19th Jun 2018 5:15pm |
While I’m waiting for some bits arriving for the piping for the provent I’ve started fitting some bits that arrived the other day
Click image to enlarge Some more security bits! I won’t go into detail of most of it but I got a pic of this fitted. Click image to enlarge It took a bit of filing and fettling to get the cowl and wires to all fit in but it looks quite neat now Every little helps Ray My build thread http://www.defender2.net/forum/topic17615.html |
20th Jun 2018 8:10pm |
Went to put new rear pads in today as the last mot advised they were getting low, got everything ready, wheel off, start pulling pads, and the calliper is seized solid on one piston and other piston only just moves put it back together and went for a sulk then ordered some new rear calipers also found a crack in the brake servo, so what started as new pads and change two bit of brake pipe that had an advisory on the mot has turned into brake pipes, front brake flexis, two rear calipers, new pads all round, a new servo and fluid change
Why do we bother with Landrover’s........... Ray My build thread http://www.defender2.net/forum/topic17615.html |
21st Jun 2018 3:22pm |
