Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats
Page 15 of 81 <123 ... 141516 ... 798081>
mk1collector
No probs Thumbs Up photobucket is driving me nuts Laughing it can't be slid on from underneath, you need to tak off the air box and flexi hoses then remove the air box bracket. Unclip the pipes and wires on the back of the engine then with a bit of bending of the cover and a couple of scraped knuckles it will go in. Then as the air box is out its the perfect time to take out the water separater thing.
Post #369051 2nd Nov 2014 4:43pm
mk1collector
Another package arrived today and with the recent thefts in the area I need to add this to my already large list of defence, although according to their website it won't fit an aircon dash so we will see how that goes Laughing
Ray
Post #369231 3rd Nov 2014 3:08pm
Tiger
Got, £20 delivered, cheers for the heads up Thumbs Up
The dining room is now kinda a parts store.
Post #369395 4th Nov 2014 9:17am
mk1collector
Thumbs Up
Post #369405 4th Nov 2014 10:04am
mk1collector
X eng pedal lock with aircon dash fitted and working Mr. Green
Just some tidying up to do and a catch to fit.
Edit: and a good clean by the look of the pics Rolling with laughter
Ray
Post #369776 5th Nov 2014 6:24pm
Tiger
Looks good Thumbs Up
I fitted the catch then took the catch off mine, found I didn't use it and it didn't rattle.
Post #369781 5th Nov 2014 6:49pm
mk1collector
I figured I'd fit it or it would just get consumed by the black hole that are my garages Rolling with laughter
Post #369817 5th Nov 2014 8:26pm
mk1collector
Gave her a good wash and wax today before the bad weather kicks in, so it's hopefully a bit more protected over winter. Im determined to wire up the heated screen and mirrors this year but I'm running out of time fast Big Cry
Post #370610 9th Nov 2014 6:16pm
mk1collector
After fitting the twin wiper mod the pressure of water coming out was a little lacking so after looking around the net I'd decided on a disco 2 headlight washer pump which supposedly has more umph but as Paul mc pointed out it was going to need its own circuit as it draws more power so I got one anyway only to find the pipe diameter was also a lot bigger, so in the end I decided on a new standard rear pump. Thanks to a previous owner the proper plug had been cut off the wiring and then bodged terminals back on so Paulmc came to the rescue again with supplying the right plug Thumbs Up
All now fitted and I'm happy to report a good strong pair of washer jets now Mr. Green
Ray
Post #371985 16th Nov 2014 2:28pm
mk1collector
Milestone Laughing
Also been sorting a leak on my newly fitted transfer box Rolling Eyes found a bolt half way out and a sensor not tight Shocked I'm hoping the leak is cured now!
Ray
Post #373031 20th Nov 2014 3:19pm
mk1collector
Yet another front sidelight bulb gone this morning so I got fed up and took a trip over to bolt on bits for a pair of these.
Hopefully no more missing lights and when I get the full set of led lights I'll have a couple of spares Very Happy
Ray
Post #374115 25th Nov 2014 11:05am
mk1collector
My mrs came home last night and told me I had to spend some money on the defender Shocked so not wanting to disappoint I made a trip over to bolt on bits again today to buy a full set of led's Mr. Green with my front side lights bought the other week I'll have a couple of spares just incase.
Should be fitting them tomorrow if it's dry. Also picked up some security screws to try and keep them on Big Cry
Cheers for looking
Ray
Post #385745 6th Jan 2015 11:24pm
mk1collector
Got them fitted today and think it looks a lot neater Mr. Green
Backs are done too but photobucket will only let me use one pic at a time then it freezes Evil or Very Mad
Just got to save up for led headlights now.
Ray
Post #385881 7th Jan 2015 11:13am
mk1collector
And the back
Post #385890 7th Jan 2015 11:36am
mk1collector
Got fed up of seeing this Big Cry
So bought these genuine panels
And I've decided I don't want them corroding again so I've dropped them off at the powder coaters to get them blasted, zinc coated, then powder coated and when I get them back they will get painted, properly sealed to the car then dinitrolled so I hope I won't need to do that job again Rolling with laughter
Ray
Post #398633 13th Feb 2015 11:22pm
