Home > Td5 > Exhaust Manifolds
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Exhaust Manifolds
In the Jan edition of LRO I cam across the below image of a custom exhaust manifold which seems to be set up for an equal length.
I wondered if anyone on here had any knowledge of this particular setup? Is this Alive tuning?
I am confused to the retention of the plastic air pipe which is known to collapse when a high volume of air is required. Especially when the standard airbox etc has been removed. It's nothing a bit of Alloy off ebay couldn't have done.
Also surprised to see and open filter in the engine bay which not only affects the offroad ability of the car but is pulling in warm air from the very warmest place in the engine bay.
Does this flow any better? Does it reduce EGT on the outer 2 cylinders?
Post #192083 9th Dec 2012 6:42pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
Mine had an open filter like that when I first had it, I didn't find the performance any better, but the noise especially when the bulkhead flaps were open was awful.
Post #192129 9th Dec 2012 8:01pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Yes it is a Alive set up, but i think if you have a word with Gary you will probably find out that its not the finished version of what hes doing. I may be wrong however lol.
Pete.
Post #192149 9th Dec 2012 8:53pm
Allan
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Can this manifold be bought.
Allan
Post #193996 16th Dec 2012 12:52pm
landy andy
Think most of the tuning companies do updated Td5 exhaust manifolds. Talk to Alive, if they don't the chat with Ian @ IRB
Andy
Post #194027 16th Dec 2012 3:14pm
me@td5.org
These are the IRB ones, not sure if Ian is selling them still.
It's not an equal length design but a better flowing tubular manifold that does not require and turbo relocation or changes to the exhaust down pipe.
Post #194030 16th Dec 2012 3:16pm
Allan
Thanks for that.
Allan
Post #194209 17th Dec 2012 12:56am
