Home > Td5 > Groaning power steering
Martin
Site Admin
I presume that an engine speed related groaning when steering is pointing to the imminent need for a new PAS pump?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #188468 26th Nov 2012 10:49am
I always thought that fell into the 'they all do that, sir' category? Mine does it occasionally when cold, but it hasn't got any worse in the nearly 18 months I've owned it, and I'm sure other Land Rovers I've owned did it too. Darren
Post #188469 26th Nov 2012 10:54am
Martin
Site Admin
Mine's just started doing it this morning Big Cry  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #188479 26th Nov 2012 11:23am
chinnus
2001 Defender 90 Td5 ST Coniston Green
mine does it all the time when cold.... would describe it more of a whhhhrrrrr than a groan... seems to be more prevailent when on lock to lock turning.... when it is warm however the noise goes away.....
my mechanic neighbour said its something to do with the PAS pump but i can't remeber exactly what... he didnt seem to think it was anything bad...
again a case of "ohh your land rover doesnt whrrrr"??
Post #188482 26th Nov 2012 11:34am
have you checked the fluid level ?
how old is the fluid ?
... hopefully other "groaning" in the "Martin-sphere" will be on the decline Thumbs Up
Post #188503 26th Nov 2012 1:22pm
Martin
Site Admin
Hmm yes well I do feel like a berk now
Appears I have a self-draining PAS system to somewhere Embarassed  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #188515 26th Nov 2012 2:01pm
I meant to ask if you defender was marking it's territory Thumbs Up
Post #188518 26th Nov 2012 2:13pm
Romadog
Sounds like air in the system to me, which could go along with being run with not enough fluid. Top up and turn steering to full lock each way. This may sort it or you may need to use the nipple on top of steering box.
Post #188572 26th Nov 2012 7:26pm
Martin
Site Admin
Topped up Embarassed and a happy chappy again Mr. Green  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #188829 27th Nov 2012 12:11pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
Mine groans all the time when turning left at low rpm. Right is quiet. Has been that way since day 1. No leaks, no low fluids. The defender has migrated, leaving the owner behind.
Post #192749 11th Dec 2012 3:51pm
excossack
Mine does the same even after swapping the steering box and new fluid. Its got no worse over the last 3 years. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #192836 11th Dec 2012 10:19pm
jst
some of the 300tdi and early td5 had groaning steering at low rpm which was to do with pipe resonance and routing apparently, there was a LR mod/tech bulletin to change the route i think (it may of replaced pipes, i cant remember now) Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #192881 12th Dec 2012 7:44am
achuakh
That's interesting, but on a 2002 it should be ok.
But if you can find that service bulletin I would check my routing of the pipe. The defender has migrated, leaving the owner behind.
Post #192941 12th Dec 2012 2:02pm
jst
mine had the recall on a 98 R plate and then again on a 99 td5. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #192943 12th Dec 2012 2:05pm
Martin
Site Admin
As mine's far from a factory Td5 it won't be the recall issue (wasn't) but good pointers for others Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #192944 12th Dec 2012 2:22pm
