Home > Td5 > Groaning power steering |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6610 |
I presume that an engine speed related groaning when steering is pointing to the imminent need for a new PAS pump? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
26th Nov 2012 9:49am |
I always thought that fell into the 'they all do that, sir' category? Mine does it occasionally when cold, but it hasn't got any worse in the nearly 18 months I've owned it, and I'm sure other Land Rovers I've owned did it too. Darren
26th Nov 2012 9:54am |
Mine's just started doing it this morning 1988 90 Td5 NAS soft top
2015 D90 XS SW |
26th Nov 2012 10:23am |
chinnus Member Since: 24 Aug 2012 Location: UK Posts: 119 |
mine does it all the time when cold.... would describe it more of a whhhhrrrrr than a groan... seems to be more prevailent when on lock to lock turning.... when it is warm however the noise goes away.....
my mechanic neighbour said its something to do with the PAS pump but i can't remeber exactly what... he didnt seem to think it was anything bad... again a case of "ohh your land rover doesnt whrrrr"?? |
26th Nov 2012 10:34am |
Hmm yes well I do feel like a berk now
Appears I have a self-draining PAS system to somewhere 1988 90 Td5 NAS soft top 2015 D90 XS SW |
26th Nov 2012 1:01pm |
I meant to ask if you defender was marking it's territory
26th Nov 2012 1:13pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
Sounds like air in the system to me, which could go along with being run with not enough fluid. Top up and turn steering to full lock each way. This may sort it or you may need to use the nipple on top of steering box.
26th Nov 2012 6:26pm |
Topped up and a happy chappy again 1988 90 Td5 NAS soft top
2015 D90 XS SW |
27th Nov 2012 11:11am |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 158 |
Mine groans all the time when turning left at low rpm. Right is quiet. Has been that way since day 1. No leaks, no low fluids. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
11th Dec 2012 2:51pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5850 |
Mine does the same even after swapping the steering box and new fluid. Its got no worse over the last 3 years. 1999 Defender TD5 110
11th Dec 2012 9:19pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8049 |
some of the 300tdi and early td5 had groaning steering at low rpm which was to do with pipe resonance and routing apparently, there was a LR mod/tech bulletin to change the route i think (it may of replaced pipes, i cant remember now) Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
12th Dec 2012 6:44am |
That's interesting, but on a 2002 it should be ok.
But if you can find that service bulletin I would check my routing of the pipe. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island. |
12th Dec 2012 1:02pm |
mine had the recall on a 98 R plate and then again on a 99 td5. Cheers
12th Dec 2012 1:05pm |
As mine's far from a factory Td5 it won't be the recall issue (wasn't) but good pointers for others 1988 90 Td5 NAS soft top
2015 D90 XS SW |
12th Dec 2012 1:22pm |
