![]() | Home > Td5 > Groaning power steering |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6661 ![]() ![]() ![]() |
I presume that an engine speed related groaning when steering is pointing to the imminent need for a new PAS pump?
I always thought that fell into the 'they all do that, sir' category? Mine does it occasionally when cold, but it hasn't got any worse in the nearly 18 months I've owned it, and I'm sure other Land Rovers I've owned did it too. Darren
Mine's just started doing it this morning
chinnus Member Since: 24 Aug 2012 Location: UK Posts: 119 ![]() ![]() |
mine does it all the time when cold.... would describe it more of a whhhhrrrrr than a groan... seems to be more prevailent when on lock to lock turning.... when it is warm however the noise goes away.....
my mechanic neighbour said its something to do with the PAS pump but i can't remeber exactly what... he didnt seem to think it was anything bad... again a case of "ohh your land rover doesnt whrrrr"?? |
Hmm yes well I do feel like a berk now
Appears I have a self-draining PAS system to somewhere ![]() ![]() ![]() |
I meant to ask if you defender was marking it's territory
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Sounds like air in the system to me, which could go along with being run with not enough fluid. Top up and turn steering to full lock each way. This may sort it or you may need to use the nipple on top of steering box.
Topped up
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
Mine groans all the time when turning left at low rpm. Right is quiet. Has been that way since day 1. No leaks, no low fluids. The defender has migrated, leaving the owner behind.
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5937 ![]() ![]() ![]() |
Mine does the same even after swapping the steering box and new fluid. Its got no worse over the last 3 years. 1999 Defender TD5 110
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8208 ![]() ![]() ![]() |
some of the 300tdi and early td5 had groaning steering at low rpm which was to do with pipe resonance and routing apparently, there was a LR mod/tech bulletin to change the route i think (it may of replaced pipes, i cant remember now) Cheers
That's interesting, but on a 2002 it should be ok.
But if you can find that service bulletin I would check my routing of the pipe. The defender has migrated, leaving the owner behind. |
mine had the recall on a 98 R plate and then again on a 99 td5. Cheers
As mine's far from a factory Td5 it won't be the recall issue (wasn't) but good pointers for others
