![]() | Home > Td5 > TD5 temperature gauge fluctuating |
Gelert7233 Member Since: 17 Nov 2013 Location: Uk Posts: 8 ![]() |
Great stuff!!
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5922 ![]() ![]() ![]() |
I replaced the temp sensor at the front of the cylinder head. Take a look at the last pic on page 4 for the location 1999 Defender TD5 110
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
If it's a wiring issue from the ECU to the gauge, an intermittent full deflection would suggest the coolant signal wire is being shorted to 12V.
The fact you're losing engine power suggests the actually it's the ECU seeing an overheat from the coolant sensor and reducing power to compensate, as well as throwing the gauge into the red. I would swap the coolant sensor as a first port of call - ERR2081 - they are a few quid. ![]() ![]() |
thefender Member Since: 25 Aug 2019 Location: kent Posts: 28 ![]() ![]() ![]() |
Hi - I had exactly the same problem and mine was arcing contacts on the main relay under the driver seat - If you remove each relay (3 to 5 of them depending on kit) and check for any burnt contacts or if its dark you may see the arcing going on like I did.
