Home > Td5 > TD5 temperature gauge fluctuating
Page 5 of 5 <12345
Gelert7233
Great stuff!! Very Happy thanks
Post #283063 17th Nov 2013 10:20pm
Super seven
Hi I’m experiencing a similar fluctuation but it goes up into red and I loose power then it final settles on cold after 20 mins of driving. A friend mentioned he had heard that wording over gear box may be causing the issue ? And advice please ?
Post #798971 21st Oct 2019 9:25pm
excossack
I replaced the temp sensor at the front of the cylinder head. Take a look at the last pic on page 4 for the location 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #798997 22nd Oct 2019 8:49am
Martin
Site Admin
If it's a wiring issue from the ECU to the gauge, an intermittent full deflection would suggest the coolant signal wire is being shorted to 12V.
The fact you're losing engine power suggests the actually it's the ECU seeing an overheat from the coolant sensor and reducing power to compensate, as well as throwing the gauge into the red.
I would swap the coolant sensor as a first port of call - ERR2081 - they are a few quid.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #799009 22nd Oct 2019 11:49am
thefender
United Kingdom 1999 Defender 110 Td5 CSW Barolo Black
Hi - I had exactly the same problem and mine was arcing contacts on the main relay under the driver seat - If you remove each relay (3 to 5 of them depending on kit) and check for any burnt contacts or if its dark you may see the arcing going on like I did.
Post #805509 9th Dec 2019 8:18pm
Page 5 of 5 <12345
