Home > Td5 > Overrun on switching the ignition off
Tiger
My TD5 seems to run for about 1second after it's switched off at the ignition.
Normal?
or will it Explode and I'll die?
Post #180412 30th Oct 2012 5:00pm
bob neville
Any signs of a higher than max oil level or diesel in the oil ?
2013 Defender 90 CSW - sold
Post #180447 30th Oct 2012 6:21pm
Retroanaconda
Doesn't the ECU control shut down?
So you turn the key off, but the ECU might wait a few seconds for some sensors to fall into range before allowing the engine to Censored down. For example it may not allow it to turn off if temperatures are too high or something like that.
Post #180470 30th Oct 2012 7:42pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Yes but if there is fuel in the oil it doesn't matter what the ECU tells the injectors there will still be combustion.
A similar effect can be seen on some diesel engines if they are allowed to run upside down for any length of time. My experience of a 2.8 Boxer van in this position was not pleasant
Post #180524 30th Oct 2012 11:00pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
Did you turn off the air con first?
Mine runs like half second more due to the ac compressor, but if I turn it off before turning off the engine, alls well. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
Post #180973 1st Nov 2012 1:27pm
Tiger
Doesn't have air con Sad
Post #181236 2nd Nov 2012 9:28am
landy andy
Does the defender know that though?
Andy
Post #181237 2nd Nov 2012 9:32am
