![]() | Home > Td5 > Overrun on switching the ignition off |
Any signs of a higher than max oil level or diesel in the oil ?
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2693 ![]() ![]() |
Doesn't the ECU control shut down?
So you turn the key off, but the ECU might wait a few seconds for some sensors to fall into range before allowing the engine to ![]() |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
Yes but if there is fuel in the oil it doesn't matter what the ECU tells the injectors there will still be combustion. A similar effect can be seen on some diesel engines if they are allowed to run upside down for any length of time. My experience of a 2.8 Boxer van in this position was not pleasant |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 160 ![]() ![]() ![]() |
Did you turn off the air con first?
Mine runs like half second more due to the ac compressor, but if I turn it off before turning off the engine, alls well. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island. |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Doesn't have air con
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5799 ![]() ![]() |
Does the defender know that though? Andy |
