Home > Technical > Left vs Right Suspension Height |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2624 |
jeepers, talk about a thread resurrection
As pointed above, this is normal for a RHD vehicle. If it really bothers you, then get some spring isolators and stack them on the left until you are happy with the level. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
9th Jun 2024 2:57pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5607 |
Gwyn Lewis does spring spacers so you can raise the lower side. Or you could buy new springs.
https://gwynlewis4x4.co.uk/product/2-x-rea...-6mm-each/ |
9th Jun 2024 3:49pm |
Kerly900 Member Since: 09 Jun 2024 Location: Heredia Posts: 2 |
Yes, I found those spring spacers, but they are only 6mm size... my difference is 30mm, so.
I also changed the original rear springs for ARB springs, I compared them to see if there is any color code or height variance... nothing both were exactly the same at least for the rear side. Anyway, I will continue investigating why is this height variance kind of "common" in Defenders and let you know my results... there should be something in the chassis, or a bushing that is damaged at the left side I guess... still investigating. Thanks fellas! |
10th Jun 2024 7:20pm |
