Home > Technical > Left vs Right Suspension Height
Page 2 of 2 <12
Naks
jeepers, talk about a thread resurrection Laughing
As pointed above, this is normal for a RHD vehicle.
If it really bothers you, then get some spring isolators and stack them on the left until you are happy with the level. --
Post #1036922 9th Jun 2024 1:57pm
landy andy
Gwyn Lewis does spring spacers so you can raise the lower side. Or you could buy new springs.
https://gwynlewis4x4.co.uk/product/2-x-rea...-6mm-each/
Post #1036930 9th Jun 2024 2:49pm
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
If you have ever replaced a set of springs you will have noticed that they are colour coded and come with instructions as to position on the vehicle where they are supposed to be installed.
The reason for this is so the vehicle sits level with just the driver. The passenger springs are a different tension so that when a front seat passenger is carried the vehicle remains level.
Jim
Post #1036932 9th Jun 2024 2:56pm
Kerly900
Costa Rica 2001 Defender 110 Td5 HT Montpellier Red
Yes, I found those spring spacers, but they are only 6mm size... my difference is 30mm, so.
I also changed the original rear springs for ARB springs, I compared them to see if there is any color code or height variance... nothing both were exactly the same at least for the rear side.
Anyway, I will continue investigating why is this height variance kind of "common" in Defenders and let you know my results... there should be something in the chassis, or a bushing that is damaged at the left side I guess... still investigating.
Thanks fellas!
Post #1037051 10th Jun 2024 6:20pm
Page 2 of 2 <12
