Home > Td5 > Test driving TD5 110, what should I look/listen out for?
BigWheels
My local garage has a TD5 110 (dark blue) van or SW, not sure. If I went for a test drive, what should I look & listen out for?
Any "normal" handling quirks I should be aware of? I have never driven a LWB Defender/Series before.
Its about £4750. What would you want for that price? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #178069 22nd Oct 2012 6:37pm
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
your in for a experience .
it will roll a bit more be a bit slower ,check what it has been used for some have a hard life.
listen for noise coming from diff, box etc
all depends on mileage ,service record
Post #178076 22nd Oct 2012 6:59pm
Lou Sparts
Before taking a test drive get down on the ground and have a very good look underneath and check the chassis,look out for rusted rear cross member,outriggers,and front dumb irons.The mechanical bits are fairly easy and cheap to repair a rotten chassis is not ! 2005 Td5 90 XS
Steve
Post #178088 22nd Oct 2012 7:22pm
jst
oil in ecu loom
loud fuel pumps Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #178119 22nd Oct 2012 8:41pm
excossack
Leaking fuel pressure regulator. Located on the drivers side (RHD) of the engine at the rear of the block. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #178122 22nd Oct 2012 8:47pm
Killer90
Site Sponsor
whining noise when the ignition is turned on, is the fuel passing through- if its loud and constant could be injector seals on there way out or even a fuel pump Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #178140 22nd Oct 2012 9:17pm
