![]() | Home > Td5 > Test driving TD5 110, what should I look/listen out for? |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1121 ![]() ![]() ![]() |
your in for a experience .
it will roll a bit more be a bit slower ,check what it has been used for some have a hard life. listen for noise coming from diff, box etc all depends on mileage ,service record |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Before taking a test drive get down on the ground and have a very good look underneath and check the chassis,look out for rusted rear cross member,outriggers,and front dumb irons.The mechanical bits are fairly easy and cheap to repair a rotten chassis is not ! 2005 Td5 90 XS
Steve |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8233 ![]() ![]() ![]() |
oil in ecu loom
loud fuel pumps Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5941 ![]() ![]() ![]() |
Leaking fuel pressure regulator. Located on the drivers side (RHD) of the engine at the rear of the block. 1999 Defender TD5 110
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
whining noise when the ignition is turned on, is the fuel passing through- if its loud and constant could be injector seals on there way out or even a fuel pump
![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
