Home > Puma (Tdci) > cruise control for Puma
Page 3 of 6 <123456>
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
If people pm me with their emails i will send you the installation instructions that come with kit and some pics that i took whilst fitting mine. I did this for Bruce earlier today, so its no problem as all the copying work is done.
I will check my inbox tomorrow and send as a oner.
Hope this helps you all.
Regards,
Mark
Post #176042 15th Oct 2012 7:57pm
BruceT
South Africa
[quote="pope10001"]If people pm me with their emails i will send you the installation instructions that come with kit and some pics that i took whilst fitting mine. I did this for Bruce earlier today, so its no problem as all the copying work is done.
Regards,
Mark[/quote
Hi Mark, thanks but I didn't receive them yet. Tdidnt want you to think I was rude by not saying thank you)
Post #176047 15th Oct 2012 8:00pm
df1
mobilecentre wrote:
df1 wrote:
Any date on the restock yet ?
On my must get list too Thumbs Up
Puma is in stock
It's the td5 I'm after.
Post #176085 15th Oct 2012 9:04pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
The Cruise control works in any gear at any speed & works with Overdrive or modified gearing.
This is what you get in the box the loom to the throttle is 't'ed in so just plug and play. Thumbs Up
Post #176109 15th Oct 2012 9:51pm
BruceT
South Africa
Thank you. Is there any splicing of original wiring?
Post #176139 16th Oct 2012 5:44am
mobilecentre
WelshGas wrote:
I understand your apprehension of buying something costing the best part of £400 - sight unseen. I too am very interested, everyone has said it is fairly straightforward but no one has been prepared to show the instructions etc:, What is actually involved in fitting it. How much dismantling of the dash etc. That concerns me that I might have problems. Whistle
I thought I had covered this, but I may of missed something.
You have to remove your steering cowl and clocks / instruments which is about eight torx screws from here you can access the bulkhead for the clutch, the speed pulse wire on the instrument loom, ignition live on the back of the key and run cables down to the brake pedeal and mount the stalk in the cowl.
The cruise ecu I would mount behine the speaker on the bulkhead.
Then you put it into set up and check operation of pedals then drive it and you are done.
Post #176164 16th Oct 2012 8:44am
mobilecentre
df1 wrote:
Puma is in stock
We are waiting on that - we have to have an ECU programmed with specific software for the Td5 which seemed very quick for initial two we did for testing and a few for stock. Now we are just waiting.
Post #176165 16th Oct 2012 8:46am
mobilecentre
Yes as you have to pick up an ignition feed, speed pulse, clutch and brake input.
Post #176166 16th Oct 2012 8:47am
ZeDefender
I think it's the dismantling part that was worrying people.
I did the same kind of dismantling etc. when I fitted my speed-unlimiter - it's p*ss easy Thumbs Up
If you do the wiring neatly (soldering and sleeving), that's what takes the time... Tell someone you love them today because life is short.
Post #176168 16th Oct 2012 8:51am
BruceT
South Africa
Ok. Thank you. Thumbs Up Was hoping for plug and play. let me give it some thought.........and work out the costs.....exchange rate is tough at the moment. Big Cry
Post #176170 16th Oct 2012 8:53am
mobilecentre
We looked at making it plug and play but the price would then put people off as it would increase heavily.
Post #176171 16th Oct 2012 8:54am
mobilecentre
I agree - taking your time is key.
Post #176173 16th Oct 2012 8:56am
BruceT
South Africa
Thanks again for all the info. You have PM. Very Happy
Post #176175 16th Oct 2012 8:59am
pope10001
Hopefully everyone that passed me their email should now have a copy of the manual and pictures i took.
Please let me know if it doesn't come through.
Regards,
Mark
Post #176176 16th Oct 2012 9:01am
BruceT
South Africa
Thanks Mark.
I have not received a copy
Post #176177 16th Oct 2012 9:03am
