![]() | Home > Puma (Tdci) > How long will it weep for? |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
OK, the inevitable has happened, the Puma's vacuum pump has a very minor weep on the engine side at the base.
![]() So does anyone have any idea how long I might get out of this? I've got a replacement ordered for Monday at the dealers in Sydney, but I have about 400 - 500km of driving to get there. I'm towing about 1.5t of trailer as well and there's a lot of hills to get over. 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
You should get quite a while. Basically it is weeping engine oil so you've got several litres to get through
![]() Mine was spraying quite a bit around the engine bay but even so, the total amount of oil was probably only 50ml. I drove a few hundred miles on it without any issues. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
Fontuin Member Since: 11 Sep 2008 Location: South Africa Posts: 29 ![]() ![]() |
I drove mine a few thousand km from when it started leaking until it was replaced with no problems other than an oily engine bay and my brakes did start feeling a little "hard" towards the end. I didn't even have to replace any oil in that time.
It doesn't leak all the time when the seal goes and I did in fact never see it leaking, only the evidence there of. |
After the initial leak, I drove for 1500km ...
No problem...... Last edited by dgardel on 17th Jul 2009 6:51pm. Edited 2 times in total |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
i did 700 ish miles on it Mike
YORKSHIRELAD Member Since: 17 Mar 2009 Location: West Yorkshire Posts: 159 ![]() ![]() |
Hi lads. Bearing in mind that I still have the original pump, and that I will inevitably need a replacement in the future, can I ask you all how many miles or Km's you had clocked up before it failed?. I don't do much mileage and although this might sound strange, I would really like it to fail whilst it's still under warranty. If I squirt oil under the bonnet, do you think I could con them into a replacement
![]() Richard 1963 Series 2A truck cab 2008 110 SW |
About 6 or 7k i think Mike
10k miles.
I considered doing the same thing ![]() I don't think they could really tell (if you use a fine enough spray ![]() + New Defender 110 First Edition |
Thanks. I should be o.k until next year then.. ![]() Richard 1963 Series 2A truck cab 2008 110 SW |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 ![]() ![]() ![]() |
Quite strange,
First one failed at 12,000 miles; second one (1st type) still working OK after 25,000 miles Something should be wrong.... ![]() ![]() Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 ![]() ![]() ![]() |
Ive done 38k and still on the original pump, May 07 Defender
road tested 3 miles all ok, told LR, can't belive it's still oil tight,will keep you posted. 2.4 90 XS
