Home > Puma (Tdci) > How long will it weep for? |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
OK, the inevitable has happened, the Puma's vacuum pump has a very minor weep on the engine side at the base.
So does anyone have any idea how long I might get out of this? I've got a replacement ordered for Monday at the dealers in Sydney, but I have about 400 - 500km of driving to get there. I'm towing about 1.5t of trailer as well and there's a lot of hills to get over. 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
17th Jul 2009 7:29am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
You should get quite a while. Basically it is weeping engine oil so you've got several litres to get through
Mine was spraying quite a bit around the engine bay but even so, the total amount of oil was probably only 50ml. I drove a few hundred miles on it without any issues. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
17th Jul 2009 9:00am |
Fontuin Member Since: 11 Sep 2008 Location: South Africa Posts: 29 |
I drove mine a few thousand km from when it started leaking until it was replaced with no problems other than an oily engine bay and my brakes did start feeling a little "hard" towards the end. I didn't even have to replace any oil in that time.
It doesn't leak all the time when the seal goes and I did in fact never see it leaking, only the evidence there of. |
17th Jul 2009 9:31am |
17th Jul 2009 1:22pm |
After the initial leak, I drove for 1500km ...
No problem...... Last edited by dgardel on 17th Jul 2009 6:51pm. Edited 2 times in total |
17th Jul 2009 5:33pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
i did 700 ish miles on it Mike
17th Jul 2009 6:00pm |
YORKSHIRELAD Member Since: 17 Mar 2009 Location: West Yorkshire Posts: 159 |
Hi lads. Bearing in mind that I still have the original pump, and that I will inevitably need a replacement in the future, can I ask you all how many miles or Km's you had clocked up before it failed?. I don't do much mileage and although this might sound strange, I would really like it to fail whilst it's still under warranty. If I squirt oil under the bonnet, do you think I could con them into a replacement . Thanks,
Richard 1963 Series 2A truck cab 2008 110 SW |
17th Jul 2009 7:08pm |
About 6 or 7k i think Mike
17th Jul 2009 9:05pm |
10k miles.
I considered doing the same thing I don't think they could really tell (if you use a fine enough spray ). The guy took one look at mine, ran his finger through the oil. proclaimed that it was definitely engine oil and certified the replacement. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
17th Jul 2009 9:24pm |
Thanks. I should be o.k until next year then.. . Richard 1963 Series 2A truck cab 2008 110 SW |
17th Jul 2009 9:26pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
Quite strange,
First one failed at 12,000 miles; second one (1st type) still working OK after 25,000 miles Something should be wrong.... Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
17th Jul 2009 10:21pm |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 |
Ive done 38k and still on the original pump, May 07 Defender
18th Jul 2009 2:40pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
road tested 3 miles all ok, told LR, can't belive it's still oil tight,will keep you posted. 2.4 90 XS
18th Jul 2009 9:00pm |
19th Jul 2009 7:31am |
