Home > Puma (Tdci) > clutch fluid flushing
MD5
2009 Defender 110 Puma 2.4 SW Alpine White
I see that clutch fluid on my Puma look gravy and dirty.
How to flush/renew the clutch fluid ?
Post #166438 5th Sep 2012 5:20am
Glynparry25
Best way would be to use a pipet and remove the fluid from the resevoir. Fill it back up with new fluid and then blead the rest through the slave cylinder untill it comes through clear.
If that makes sense.
Glyn Dog Sheep
Post #166440 5th Sep 2012 6:04am
MD5
Thanks for the information.
I already flushed the reservoir but I'm a little confused about how to bleed from the slave cylinder, any info please ?
Post #166444 5th Sep 2012 6:24am
Happyoldgit
Traditional method was to attach a flexible pipe to the bleed nipple on the slave cylinder, place free end of pipe in a jar which has a quantity of brake fluid making sure end of pipe is immersed in fluid, top up reservoir, get assistant to sit in car and press clutch pedal down while bleed nipple is opened, close bleed nipple while pedal is still down - repeat until all air / dirty fluid has been expelled.
Alternatively use bleed kit which pressurises the hydraulic system and enables the bleed nipple to be opened and fluid to be expelled under pressure. Steve.
http://forums.lr4x4.com
Post #166469 5th Sep 2012 10:02am
Glynparry25
As Steve says,
You can do it on your own but best with 2 people (or 3 if you have the ability).
Person 1: Responsible for pumping the clutch pedal and making sure the resevoir doesn't get less than half.
Person 2: Responsible for the control of the process and loosesn/ tightens the bleed nipple.
Person 3: If available can make sure the resevoir never gets low- therefore letting person 1 chill out with only pedal pushing to do.
Gets under the car with a tube that can be poped over the end of a nipple (Bleed nipple not human nipple). the other end of the pipe goes in to a bottle of some sort (empty coke bottle is fine).
If you follow the pipe under the vehicle it will have a flex section near along the side of the gearbox which then goes up into a hard pipe- this ends with a 'Banjo type fixing with a bleed nipple (with a rubber cap on it). Put a 10mm ring spanner on it and then the pipe...... turn untill loose.
Person 1 now starts pumping the clutch pedal...... fluid will start flowing through the pipe. Keep pumpinguntill it is clear (new fluid). Just make sure that the resevoir doesn't drop low otherwise you will have air in the system and the clutch won't work.
Once clear.... Person 2 tells Person 1 to stop and hold. Once the pedal is down and held person 2 then tightens up the bleed nipple. Process complete!
Final checks- Resevoir fluid is correct level and there is a good feel on the pedal.
*******Just as an after thought there are probably guides on how to do it on youtube and the like.******
Best of luck, Thumbs Up
Glyn Dog Sheep
Post #166471 5th Sep 2012 10:26am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
for a 1 man job use Gunson Ezibleed.
http://www.screwfix.com/p/eezibleed-brake-...fAodWGQAHA
as very easy........just don't have too much pressure in the spare tyre Rolling Eyes BM52
Post #166588 5th Sep 2012 8:30pm
MD5
Thanks again for how-to informations!
Since I like to work alone I will try to find locally the Gunson Ezibleed or something similar.
Post #167774 12th Sep 2012 6:49am
Caterham
any thoughts -
had my 'gravy' - sorry clutch fluid flushed through the other day and was nice n clear when I left garage. a couple of weeks later and it's gravy again?
what could cause the contamination - wrong fluid partially shagged the seals and therefore not always getting full clutch action hence occasional poor gear change?
if so do the different LR's use different fluids ie mineral, synthetic, dot 2 and 4 etc?
and would a replacement gearbox require any action with the clutch fluid ie topping up?
Thumbs Up
Post #424974 20th May 2015 7:08am
munch90
Clutch fluid in all cars seems to go black now days , dont know why
Post #425187 20th May 2015 8:43pm
Caterham
seems strange that?
bought some nice new brakes for my MTB and the guys who supplied them put wrong fluid in and trashed all the seals Sad
discolour is nothing to worry about tho? - thanks.
Post #425199 20th May 2015 9:28pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
It looks dark after a few weeks because the cylinder is made of metal and no light can penetrate the sides (like the brake fluid reservoir)
You can only see the top... thats why. If you use a torch you are able to see it's still relatively clear (in my case)
I was able to bleed mine on my own about a month ago. Here is my tip -
# cut a 13mm spanner in half. It will make it much easier to unscrew the clutch bleed nipple as there are a few things in the way.
Just fit your bleed tube onto nipple, unscrew nipple 1/2 a turn. pump pedal slowly down, slowly up 3 times. Top up fluid level. Pump 3 more times. top up fluid. and repeat until you are happy it is flushed.
Thats what i did on my own. 1953 80"
1987 mini city e
2011 90"
Post #425209 20th May 2015 9:47pm
munch90
Must admit it doesnt look nice , but they seems to put up with it ok
in the bottom of the master cylinder there is a kind of sump that the crap sinks in to thats a bit lower then the inlet hole
what you can do is use a biggish syringe with a 2-3 inch pipe on to the suck the crap out of the bottom every now and then and also suck out fluid and top up again with fresh fluid , just to keep fluid bit flesher and keep crap to a lower level and easier then climbing underneath and means you can do it more often
guessing most will know this but keep fluid away from any paintwork !
Post #425214 20th May 2015 9:56pm
Changing the clutch fluid does not seem to be a maintenance check sheet item which seems odd to me?
Post #425283 21st May 2015 9:57am
munch90
by the time it needs changing you need a clutch anyway so when bleeding the new cylinder its changed anyway !!
Post #425286 21st May 2015 10:13am
Caterham
not saying it's right or wrong but I must say it seems strange that the fluid would get contaminated / discoloured so quickly?
anyhow while the gear box is apart for new clutch, extension shaft, spigot bearing etc going to have a new slave cylinder too - don't wanna have to take g.box out again anytime soon.
(then hopefully new front axle and shocks all round) - if that doesn't sort things I'm going to move on, enough is enough.
Post #426119 25th May 2015 2:20pm
