Home > In Car Electronics > The definitive Defender ICE thread
Page 17 of 69 <123 ... 161718 ... 676869>
Steve, thanks, that is more or less the conclusion I had come to. The only problem is that that wire actually isn't present in the harness supplied to connect the Kenwood connector on the HU to the DIN connector on the vehicle harness. So to add it I would need a terminal insert for both connector shells.
The DIN connector on the LR includes both IGN ON and LIGHTS ON signals and I wouldn't mind betting that the connectivity is present on the HU connector if I could find out where. I'll see if I can find a tech support contact for Kenwood and ask the question.
Post #190718 3rd Dec 2012 9:38pm
Good luck, Thumbs Up I see the issue that you have much clearer now. What puzzles me is why it's not included? There also seems to be hardly an info in the manual either. Confused I didn't actually know there was the dimming control in the Defender harness as I've never really looked into detail what is there as I've never used it because as I previously mentioned my HU uses a sensor instead to auto dim to light conditions all by it's self. Perhaps on top of contacting technical support with Kenwood I'd have a good look through Google search if you can as it's likely others may have had the same issue.
Steve
EDIT* In the mean time have a look at page 28 here: http://images.kenwood.eu/files/prod/2062/5...1U(EN).pdf
There maybe a setting there that you can dim it to without having to worry about the dimming wire. â­ï¸â­ï¸God Bless the USA 🇬🇧🇺🇸 â­ï¸â­ï¸
Post #190724 3rd Dec 2012 9:48pm
jerseyman
custom90steve wrote:
jerseyman wrote:
Steve,
Lazy of me I know, but there is now so much info on upgrading the Landy ICE that I have succeeded in educating myself into indecision.
If the budget was higher - C£800 including fitting what would you suggest, it's a 90 Puma with full noisekiller soundproofing, would mostly listen to voice, rock and blues.
A Kenwood KVT526DVD system with Kenwood BT300 add on along with upgrading all four 10cm speakers with the Kenwood top of the range equivilent size. All available from Just Kenwood. I would imagine you could get all of this for that budget. not sure about the fitting though but I would seriously think about doing it yourself it isn't as difficult as it may first seem. If you do decide to you know who to ask for advice by PM. If you have sound proofing also that will help also. If you want a sub, amp & tweeters ect then it will cost a considerable amount more on-top but worth it equally. Thumbs Up
Shame your so far away or I would happily fit it in for you.
HU (No available but probably is elsewhere) http://www.justkenwood.co.uk/car-audio.asp...dia-system
BT add on: http://www.justkenwood.co.uk/car-audio.aspx/kca-bt300-adaptor
10cm speakers: http://www.justkenwood.co.uk/car-audio.aspx/kfc-s1094-speakers
Thanks Steve, I really appreciate the time an trouble that you take to help people out out. I will assume that I can fit the stuff myself so that gives c £800 on components.
That HU is probably more than I need, so do you think that http://www.justkenwood.co.uk/car-audio.aspx/kiv-700-car-radio will give as good radio and MP3 quality?. If so that frees up enough budget to get the Kenwood active sub woofer.
The £40 speaker look excellent value, I still have enough to spend a little more than that, or do you reckon that would be diminishing returns bearing in mind the Landie acoustics?.
Thanks once again for all the help
Brian
Post #190799 4th Dec 2012 11:21am
jersey man (Brian) - That HU should be perfect yes but bear in mind it has no CD capability but probably like mine you won't use it anyway. You should be fine fitting it yourself no probs and you always have the manual / on-line or you could ask me if you have any issues. With the speakers I would suggest the £40 one's as there is no capability to fit larger speakers in the OE Defender speaker aperture due to clearance in the rear. However if you want to go further later on you may consider an amp for added bass & premium tweeters. 6x9's are also an option. IMHO power = quality at least with premium bands anyway.
Steve
Thumbs Up â­ï¸â­ï¸God Bless the USA 🇬🇧🇺🇸 â­ï¸â­ï¸
Post #190816 4th Dec 2012 12:45pm
110SEB
So I eventually plumped with the Sony MEX-BT3000 CD Radio with Bluetooth (for which no ISO connector was required) and i'm really pleased with it. Good sound pick up and very clear sound out. I can recommend it for Bluetooth telephoning with an iPhone.
Photo to follow.
Post #191210 5th Dec 2012 5:27pm
^^^^ Good brand that too. Pictures would be great. Thumbs Up â­ï¸â­ï¸God Bless the USA 🇬🇧🇺🇸 â­ï¸â­ï¸
Post #191219 5th Dec 2012 5:52pm
nidge n
a question from a novice. i am looking for a unit that is easy to self fit, has bluetooth and ideally SD card. Any recommendations please? go easy with me Big Cry
Post #191597 7th Dec 2012 1:28pm
Just popping out right now. I'll have a look around for you later on. Thumbs Up â­ï¸â­ï¸God Bless the USA 🇬🇧🇺🇸 â­ï¸â­ï¸
Post #191602 7th Dec 2012 1:38pm
nidge n
Thank you, i found a pioneer but no idea on performance and interface with the defender. I appreciate your help Thumbs Up
Post #191612 7th Dec 2012 2:12pm
nidge n - Pioneer is one of the good brands but personally I would have a look here:
justkenwood.co.uk
Only Kenwood on there have a look though to see what you fancy and what suits you best and let me know. Thumbs Up Thumbs Up â­ï¸â­ï¸God Bless the USA 🇬🇧🇺🇸 â­ï¸â­ï¸
Post #191666 7th Dec 2012 6:05pm
nidge n
justkenwood.co.uk
some great units here and one that will suite my needs. Thank you steve for your help. One last question if i may? are they plug and play as far as taking out the old unit and replacing it with the Kenwood?
Post #191694 7th Dec 2012 8:13pm
nidge n wrote:
Some great units here and one that will suite my needs. Thank you Steve for your help. One last question if I may? are they plug and play as far as taking out the old unit and replacing it with the Kenwood?
Glad you found some you like. Thumbs Up The Defender 2007> uses an ISO connector as standard for the OE LR radio. And for after-market units such as Kenwood (and other brands) they also use ISO connectors so you will simply need two ISO universal round radio keys to remove your original HU. A single DIN radio cage for the Kenwood & a pair of Kenwood radio release keys. (Both very cheap, Both available on JustKenwood) it will just plug straight in and so will the Defender aerial also as it is standardised too. Double check that the cables / wires just below don't interfere with the controls i.e. the fans ect.
Thumbs Up
Steve â­ï¸â­ï¸God Bless the USA 🇬🇧🇺🇸 â­ï¸â­ï¸
Post #191705 7th Dec 2012 9:06pm
Storming
Scotland 2007 Defender 90 Puma 2.4 HT Blenheim Silver
More help for another novice
Is there a unit that has Bluetooth that deals well with multiple phones. Looking to change standard radio to one with Bluetooth to prevent young un's picking up their phone
Thanks
S
Post #191767 8th Dec 2012 10:23am
Storming
Not at the same time but different drivers
Post #191775 8th Dec 2012 11:06am
Re: More help for another novice
Thanks
S
Do you mean that you want to 'pair' your own phone using the BT on your phone and head unit BUT prevent other phones pairing with the HU's BT system? If so I believe that's possible for sure. At least with the higher end HU's anyway.
Post #191776 8th Dec 2012 11:08am
