![]() | Home > Technical > cable weight for split charge |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
Use 16mm2 on your fuse box if you can and minimum of 35mm2 elsewhere, twist the arm of your marine engineer and get him to use tinned cable if he can which will be better still in a LR. |
Somehow I do not think Mike is referring to a 24v FFR LR but to a Toyota LC. At least Mike knows where to come to give/receive advice! Brendan |
thanks Tim
- bpman |
pjh Member Since: 23 Nov 2010 Location: West Yorkshire Posts: 126 ![]() ![]() ![]() |
Hi
I used a Blue Sea controller with 50mm tinned cable - just in case ![]() ![]() All the best, Peter Defender 11MY USW |
Sounds perfect to me ![]() |
all done ... that ought to do it
![]() ![]() Click image to enlarge |
Please note that if you wish to use the BP mans method of putting in a fuse box then be careful what fuse box you buy.
There are at least two types of 12 gang fuse box with common negative bus bar. Yes they look very similar but whereas the Blue Sea one has a marginally smaller footprint it's overall height is about 1/2" or 12 mm less the other one commonly available. If I remember I will measure both of them and post measurements up. Brendan |
Did you use any fuses? I see the OE LR one is still there? |
Blue Sea 12 way ![]() |
That'll be me then! ![]() See you soon matey! ![]() Treat every day as if it is your last....one day you will be right!! |
So Blue Sea is 164 x 84 x 39mm
The non Blue Sea is 164 x 94 x 57 mm So the Blue Sea is about 18 mm or 3/4" lower then it's rival. Brendan |
not sure what you mean Tim, the fuse box in the photo is the aux fuse box, so far 12v sockets and bluesea controller wired up... NL 50l Weekender fridge, 40" LED bar, 4" LED work light bar to be added. @K9F - thanks again for all your help ... see you for a beer soon ![]() |
