Home > Technical > cable weight for split charge |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 |
Nice |
7th Jul 2012 7:27am |
Use 16mm2 on your fuse box if you can and minimum of 35mm2 elsewhere, twist the arm of your marine engineer and get him to use tinned cable if he can which will be better still in a LR. |
7th Jul 2012 7:28am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
Somehow I do not think Mike is referring to a 24v FFR LR but to a Toyota LC. At least Mike knows where to come to give/receive advice! Brendan |
7th Jul 2012 7:34am |
thanks Tim
- bpman |
7th Jul 2012 7:58am |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
7th Jul 2012 9:38am |
pjh Member Since: 22 Nov 2010 Location: West Yorkshire Posts: 126 |
Hi
I used a Blue Sea controller with 50mm tinned cable - just in case I then stole BPman's setup (not literally ) and used 16mm to connect to the auxiliary fuse box. All the best, Peter Defender 11MY USW |
7th Jul 2012 9:25pm |
Sounds perfect to me job well done. |
8th Jul 2012 12:22pm |
all done ... that ought to do it
Click image to enlarge |
8th Jul 2012 4:35pm |
Please note that if you wish to use the BP mans method of putting in a fuse box then be careful what fuse box you buy.
There are at least two types of 12 gang fuse box with common negative bus bar. Yes they look very similar but whereas the Blue Sea one has a marginally smaller footprint it's overall height is about 1/2" or 12 mm less the other one commonly available. If I remember I will measure both of them and post measurements up. Brendan |
8th Jul 2012 5:24pm |
Did you use any fuses? I see the OE LR one is still there? |
8th Jul 2012 5:30pm |
Blue Sea 12 way |
That'll be me then! Old auxilliary fusebox cables removed (by Steve) used as a pattern and 20mm2 replacements made. Thanks for the hospitality Steve, scones strawberry jam and clotted cream (can feel my arteries clogging as I type). Mrs Bpman does make a lovely cuppa! Loved the new place - bags of potential. First dibs on a dozen eggs when you get your chickens! See you soon matey! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
8th Jul 2012 5:57pm |
So Blue Sea is 164 x 84 x 39mm
The non Blue Sea is 164 x 94 x 57 mm So the Blue Sea is about 18 mm or 3/4" lower then it's rival. Brendan |
8th Jul 2012 6:08pm |
not sure what you mean Tim, the fuse box in the photo is the aux fuse box, so far 12v sockets and bluesea controller wired up... NL 50l Weekender fridge, 40" LED bar, 4" LED work light bar to be added. @K9F - thanks again for all your help ... see you for a beer soon |
8th Jul 2012 6:41pm |
