Home > Technical > cable weight for split charge
Page 3 of 3 <123
mobilecentre
@BPman
Just wondered if you added any fuses into the system, such as for the second battery from the Blue Sea relay or the supply to the fuse box?
Post #154413 8th Jul 2012 8:34pm
mobilecentre wrote:
@BPman
no, i'm trying to keep the connections to a minimum so I used the same diagram as provided with the relay. the aux fuse box is the only output from the aux battery and each item is individually fused.
i kept the car battery fuses as OEM, ie the mega fuse is still there for the starter
Post #154415 8th Jul 2012 8:43pm
BigRuss
BigMike wrote:
Thanks all.
BigRuss wrote:
Wow 3 batteries! You trying to run your own nuclur plant?
it's a 24v start - could run the accessories from the second batt but its needed for starting so want to be 100% safe due to what the vehicle is doing/where its going. the fridge would be fine off the second batt as it has the auto shut down but since it will be parked for days at a time and i'll need the fridge to be working i need the 3rd batt.
I see Russell
2011MY 110 XS USW Black
Post #154416 8th Jul 2012 8:48pm
mobilecentre
bpman wrote:
mobilecentre wrote:
@BPman
It is a tough one, all the customer cars I have done I have put 300A fuses to protect each battery. A few I have fused the Blue Sea fuse boxe supply at 100A some I have not.
Post #154421 8th Jul 2012 8:53pm
Page 3 of 3 <123
