Home > Technical > ATB (torsen) front and rear install
Page 6 of 24 <123 ... 567 ... 222324>
ericvv
Post #426139 25th May 2015 3:54pm
^^ agreed Eric, but given LR tolerances, things will wear unless you go fully ashcroft / entreq Whistle
Post #426140 25th May 2015 4:04pm
ericvv
I actually mentioned to Olaf when I was at Entreq that I saw these two new items, but he did not seem to see an urgency for me to have this done any time quickly now after he heard that I had LR replacement half shafts already since about a year now. Will have another word about it with him later this week when I will pick up the SVX.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #426148 25th May 2015 4:24pm
mikeh501
Why not just get the proven Ashcroft items? I have their shafts and drive members and they are lovely bits of kit.
Post #426168 25th May 2015 5:40pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I have Aschroft too in the rear axle and believe they are a lot cheaper. Looks like Entreq doesn't even touch the front axle while you can get Aschroft for the front too. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #426351 26th May 2015 10:47am
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
+1 for ashcroft shafts cvs and flanges 2004 TD5 Defender 90 xs station wagon
Post #426579 27th May 2015 7:59am
+ another 1 for Ashcroft.
ATB diffs F&R, HD halfshafts and flanges F&R, HD CV joints. At last a decent driveline! Thumbs Up
Just the D44 DC front propshaft and Ashcroft TB centre diff left to fit!
Post #426601 27th May 2015 10:10am
Lorryman100
I have just ordered two ATB LSD from Ashcrofts so was wondering of those who have fitted these LSD, did you use a LSD gear oil in the diffs?? I was thinking along the lines of Fuchs Titan Race Syn 5 75w-90:
http://www.opieoils.co.uk/p-850-silkolene-...5w-90.aspx
Any thoughts folks??
Post #427460 31st May 2015 11:30am
Fuchs Titan Race Syn 5 75w-90 is exactly what I am running in the OEM and now the ATBs Thumbs Up
Post #427469 31st May 2015 12:18pm
mikeh501
Bog std stuff in my rear axle. I was under the impression the atb doesn't need any special oils.
Post #427509 31st May 2015 4:22pm
Ashcroft Transmissions say use standard oils in the ATB, ie the same as you would in LR diffs.
Post #427640 31st May 2015 10:10pm
Beery
Australia 2015 Defender 130 Puma 2.2 HCPU Corris Grey
Do the ATB's have any effect on turning circle?
Post #430559 13th Jun 2015 1:08am
Shouldn't but I'll confirm later - my front lsd is going in today Thumbs Up
Post #430565 13th Jun 2015 6:03am
None whatsoever.
Why would they?
Post #430596 13th Jun 2015 9:59am
Mine did Rolling Eyes whilst the truck was on the ramp I took the time to properly adjust the stops
Fitted a new fulcrum too
Transmission transformed Thumbs Up Truck feels planted on road
Post #430702 13th Jun 2015 5:56pm
