Home > Technical > ATB (torsen) front and rear install |
How about this stuff here? Seems built to much higher quality specs with tighter tolerances....
http://www.entreq.de/reinforcement-gear/an...achse.html http://www.entreq.de/reinforcement-gear/an...ehmer.html You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
25th May 2015 2:54pm |
^^ agreed Eric, but given LR tolerances, things will wear unless you go fully ashcroft / entreq
25th May 2015 3:04pm |
I actually mentioned to Olaf when I was at Entreq that I saw these two new items, but he did not seem to see an urgency for me to have this done any time quickly now after he heard that I had LR replacement half shafts already since about a year now. Will have another word about it with him later this week when I will pick up the SVX.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
25th May 2015 3:24pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I have Aschroft too in the rear axle and believe they are a lot cheaper. Looks like Entreq doesn't even touch the front axle while you can get Aschroft for the front too. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
26th May 2015 9:47am |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 |
+1 for ashcroft shafts cvs and flanges 2004 TD5 Defender 90 xs station wagon
27th May 2015 6:59am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17353 |
+ another 1 for Ashcroft.
ATB diffs F&R, HD halfshafts and flanges F&R, HD CV joints. At last a decent driveline! Just the D44 DC front propshaft and Ashcroft TB centre diff left to fit! |
27th May 2015 9:10am |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
I have just ordered two ATB LSD from Ashcrofts so was wondering of those who have fitted these LSD, did you use a LSD gear oil in the diffs?? I was thinking along the lines of Fuchs Titan Race Syn 5 75w-90:
http://www.opieoils.co.uk/p-850-silkolene-...5w-90.aspx Any thoughts folks?? |
31st May 2015 10:30am |
Fuchs Titan Race Syn 5 75w-90 is exactly what I am running in the OEM and now the ATBs
31st May 2015 11:18am |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
Bog std stuff in my rear axle. I was under the impression the atb doesn't need any special oils.
31st May 2015 3:22pm |
Ashcroft Transmissions say use standard oils in the ATB, ie the same as you would in LR diffs.
31st May 2015 9:10pm |
Beery Member Since: 16 Nov 2014 Location: NSW Posts: 36 |
Do the ATB's have any effect on turning circle?
13th Jun 2015 12:08am |
Shouldn't but I'll confirm later - my front lsd is going in today
13th Jun 2015 5:03am |
None whatsoever. Why would they? |
13th Jun 2015 8:59am |
Mine did whilst the truck was on the ramp I took the time to properly adjust the stops
Fitted a new fulcrum too Transmission transformed Truck feels planted on road |
13th Jun 2015 4:56pm |
