![]() | Home > Puma (Tdci) > tdci power los |
Use carb cleaner - it's safe and gets all the sh*t off in seconds
![]() But shout it at them in German because life is also terrifying and confusing... |
chopperpk Member Since: 14 May 2012 Location: sunderland Posts: 32 ![]() ![]() ![]() |
Thanks for that i will give it a go
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6321 ![]() ![]() ![]() |
chopperpk
you say it got back from rippon ok....did ripon do anything or was it a case of a good clean with carb cleaner did the trick? |
td5 commercial Member Since: 20 Mar 2011 Location: Nr Taunton, Somerset Posts: 18 ![]() ![]() |
Had this happening to a customers 110, found it was low in coolant, getting a little warm and cutting the power on hills, I found the egr coler had split internally, anyone else come across this?
how the heck did you trace it to that - well done.
I'm all for checking as much as I can. as sugestions on what to look for? presumably disconnecting the egr would confirm if this might be a problem? |
Pressure tested the vehicle and no external leaks, started thinking mabey head gasket, but thought it may be worth a go removing egr cooler, so took the egr cooler out to find water inside(where the exhaust gasses pass through).bench tested it by blocking up the water pipe(return) and put pressure thought the water inlet to find there was a pin prick hole in the cooler allowing the water to escape and be burnt! It did surprise me as head never head of this before. |
