Home > Puma (Tdci) > tdci power los
Page 2 of 2 <12
ZeDefender
Use carb cleaner - it's safe and gets all the sh*t off in seconds Thumbs Up Tell someone you love them today because life is short.
Post #145824 18th May 2012 7:42pm
chopperpk
England 2013 Defender 90 Puma 2.2 HT Tamar Blue
Thanks for that i will give it a go Thumbs Up cycle
Post #145889 19th May 2012 7:19am
chopperpk
Thumbs Up after geting back from ripon .my landy made it there and back with no faults so thay done the trick cycle
Post #148749 5th Jun 2012 3:33pm
Caterham
chopperpk
you say it got back from rippon ok....did ripon do anything or was it a case of a good clean with carb cleaner did the trick?
Post #213470 22nd Feb 2013 10:35pm
td5 commercial
2014 Defender 90 Puma 2.2 HT Baltic Blue
Had this happening to a customers 110, found it was low in coolant, getting a little warm and cutting the power on hills, I found the egr coler had split internally, anyone else come across this?
Post #213477 22nd Feb 2013 11:18pm
Caterham
how the heck did you trace it to that - well done.
I'm all for checking as much as I can. as sugestions on what to look for?
presumably disconnecting the egr would confirm if this might be a problem?
Post #213491 23rd Feb 2013 5:53am
td5 commercial
Pressure tested the vehicle and no external leaks, started thinking mabey head gasket, but thought it may be worth a go removing egr cooler, so took the egr cooler out to find water inside(where the exhaust gasses pass through).bench tested it by blocking up the water pipe(return) and put pressure thought the water inlet to find there was a pin prick hole in the cooler allowing the water to escape and be burnt! It did surprise me as head never head of this before.
Post #213509 23rd Feb 2013 8:25am
Page 2 of 2 <12
