Home > Maintenance & Modifications > Bumper treatment Galv/Powder Coating?
The Musketeer
United Kingdom 1988 Defender 90 Other HT Cairns Blue
More questions! Hope you all don't mind my constant querying, if anyone needs to know any thing about deer, guns, or quad bikes let me know!
I would like to galv or powder coat the new bull bars and existing bumper. Does anyone know where to get it done, if its possible and a rough price? I have in my head it's very expensive, but not sure. The other option is re-applying the plastic coating, but I don't know what it actually is.
Atb
Sam
(Edited because it was late, I was tired and got everything wrong) Good things come to the wild and free
Post #136010 31st Mar 2012 10:07pm
I think you might have the different processes a bit mixed up. Shot or bead blasting is used to de-rust and /or strip off old coatings, whilst galvanising is a protective coating that you'd have applied afterwards. You can also get it powder coated (plastic coated), which gives a coloured coating. You can have the powder coating applied over a galv coating, but the finish will depend on how good the galv coating is.
I've just had some tubular side steps galvanised (for free as it happens) and I've now taken them and some other galv bits to be powder coated. I'm not sure about your part of the world (United Kingdom doesn't give much away Rolling Eyes ) but the company I've found here in Berkshire has a minimum charge of £45. Darren
Post #136022 1st Apr 2012 7:36am
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
You may find powder coating really hard to remove 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #136032 1st Apr 2012 9:05am
WarPig
You can buy galv bumpers, the one on my 300tdi cost £30 from Paddocks....
Post #136059 1st Apr 2012 12:06pm
hopeydaze
United Kingdom 2006 Defender 90 Td5 SW Cairns Blue
Land Rover Anorak
Do you mind telling me who you used in Barkshire to do your galvanizing? I live in Twyford, just east of Reading so hopefully your contact isn't too far away.
Post #136070 1st Apr 2012 3:02pm
The Musketeer
Thanks mate. I'm in north Cumbria (Penrith area), I'm sure I said that in the profile thing - but obviously not!
Cheers for the info. Powder coating sounds quite a good idea
Sam Good things come to the wild and free
Post #136084 1st Apr 2012 4:45pm
hopeydaze wrote:
Land Rover Anorak
Swallow Spray Services in Windsor. Can't vouch for their quality as I haven't collected the finished work yet, but they were helpful enough. Darren
Post #136110 1st Apr 2012 6:00pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
I would just go for PC on its own get them to pre heat the bumper as you get a better coating my winch bumper was £45 with some other bits my tree sliders are Galv and Pc but I dosent stick to it and is peeling off.
Post #136130 1st Apr 2012 7:00pm
AndrewS
Galvanizing cost around £175 per tonne. Anything you take to the galvanizers must be clean and free from paint etc this normally involves shot blasting. 130's have feeling's as well you know Smile
Post #136160 1st Apr 2012 8:14pm
To be honest, my experience of plastic coated stuff is that it's a limited life finish that's then a sod to repair. The slightest nick or imperfection and water gets under it, rusts the metal and it starts to peel off. The only powder coated thing I've ever owned that didn't do that was a Safety Devices roof rack and I believe that was zinc coated underneath.
The tubular side steps and NAS step that came with my 110 were both in a shocking state and the latter was only two years old, which was why I decided to have the side steps galvanised first. The folks doing the powder coating tell me that there's a wash of some sort that they do first that helps the powder coating stick to the galv. Darren
Post #136166 1st Apr 2012 8:38pm
The Musketeer
Do you need a tonne? No idea how much my stuff will weigh... Good things come to the wild and free
Post #136168 1st Apr 2012 8:58pm
Laurie
I wouldn't touch powder coating. One pin hole to let the water in and it's finished. You'd need to galvanise it first anyway.
Post #136172 1st Apr 2012 9:23pm
Mountain_man
Wales
No. But they usually have a minimum charge of say £50 and then a per kilo price over and above that (say 20 pence a kilo). Obviously there will be bulk discounts for larger objects. So if you only have small stuff then worth asking around your local area engineering wsorks to see if anyone has a batch going in which you can add your bumper to and negotiate a price with them. Otherwise, unless you are sending a chassis and a bulkhead together you are unlikely to be sending enough weight to cover the min charge and so can reckon on this being your cost for the job. It is really not that expensive for the peace of mind I find. On my rebuild I have had every iron-based component sent to the galveniser.
Post #136195 2nd Apr 2012 6:51am
farmer giles
http://www.ashtreelandrover.com/
this company may be able to help. Met the guy a couple of yours ago at the show and he seamed to really know his stuff
Post #136219 2nd Apr 2012 9:59am
ZeDefender
I am also learning this - rather more rapidly (and on more parts) than I'd like Rolling Eyes Tell someone you love them today because life is short.
Post #136268 2nd Apr 2012 1:05pm
