Home > Puma (Tdci) > New technical bulletin regarding brake vacum pump (LTB00177
Page 3 of 3 <123
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
I've joined this club over the weekend, probably done the most miles on the original pump (40k).
I went to check the oil, water, etc under the bonnet on Saturday and noticed the oil spray all over the underside of the bonnet.
This happened at 11am (saturday of bank holiday w/e), I rang Land Rover assist and the guy was with me within 45 minutes (11:40ish). He took the old one off straight away and went off to James Edwards in Chester to get a replacement. 2 Hours later new part on (with XP code).
Can't fault the service at all, this makes up for the part going in the first place
Post #15004 3rd Sep 2009 1:46pm
red Defender
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Bonatti Grey
Having replaced several vacuum pumps I was keen to ensure the replacement pump on my 09 Puma was the latest available. There is some confusion with the latest tech bullitin, as shown by Eduardo. The latest version of the pump has been in production since late January 2009. The bulitin says it should be 148** but LR didnt tell the makers. Therfore pumps are still being manufactured with the old number 12384. After the number there is a date code, eg 31D09, this would be a pump manufactured 31st April 2009 and would therefore be the latest version.
My origional pump failed at 5000miles and the new one has survived 2000, so hoping the problems solved. I still carry a spare all the time, and can change it in under 20 minutes. Whats broken now ?
Post #15031 3rd Sep 2009 7:40pm
mse
there are actually 3 versions.
The 2nd replaced teh 1st and went straight to protected stock in the UK and couldnt be ordered...in theory if you have one of these fitted off this list (i have) then its the latest as these were check and distributed centrally specially.
The 3rd has not long been released. Mike
Post #15033 3rd Sep 2009 7:50pm
fekete
Had mine replaced today the dealer says its the latest version Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #16071 30th Sep 2009 4:24pm
Grockle
Whats the LRO no on the pump. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #16073 30th Sep 2009 4:45pm
fekete
Hi bud its a 30 G 09 Does that help Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #16077 30th Sep 2009 5:01pm
Grockle
Looks like the latest mate. 2.4 90 XS
Post #16078 30th Sep 2009 5:34pm
fekete
Cheers bud Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #16079 30th Sep 2009 5:38pm
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
Hi, my brake vacuum pump begins to lose oil, not too much, but there is a slight halo near the pulley.
My 110 is of January 2009 and it has 33.000 km now, do you think I can require the substitution from LR? Matteo
Defender 110 Td4 SE MY 09
Post #16965 21st Oct 2009 8:48am
fekete
If its leaking take it to the dealer they will replace it for you Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #16971 21st Oct 2009 9:25am
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
so, i am welcoming to the club Very Happy after 56.000Km. must be a world record or no ?
should i try for replacement ? my def was manufactured at '07, so i suppose it is the first ''edition'' of pump. Confused www.newfoundland.gr
Post #345964 18th Jul 2014 8:18am
Page 3 of 3 <123
