Home > Puma (Tdci) > New technical bulletin regarding brake vacum pump (LTB00177 |
red Defender Member Since: 11 Feb 2008 Location: Cornwall Posts: 76 |
Having replaced several vacuum pumps I was keen to ensure the replacement pump on my 09 Puma was the latest available. There is some confusion with the latest tech bullitin, as shown by Eduardo. The latest version of the pump has been in production since late January 2009. The bulitin says it should be 148** but LR didnt tell the makers. Therfore pumps are still being manufactured with the old number 12384. After the number there is a date code, eg 31D09, this would be a pump manufactured 31st April 2009 and would therefore be the latest version.
My origional pump failed at 5000miles and the new one has survived 2000, so hoping the problems solved. I still carry a spare all the time, and can change it in under 20 minutes. Whats broken now ? |
3rd Sep 2009 6:40pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
there are actually 3 versions.
The 2nd replaced teh 1st and went straight to protected stock in the UK and couldnt be ordered...in theory if you have one of these fitted off this list (i have) then its the latest as these were check and distributed centrally specially. The 3rd has not long been released. Mike |
3rd Sep 2009 6:50pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Had mine replaced today the dealer says its the latest version NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
30th Sep 2009 3:24pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
Whats the LRO no on the pump. 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
30th Sep 2009 3:45pm |
Hi bud its a 30 G 09 Does that help NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
30th Sep 2009 4:01pm |
Looks like the latest mate. 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
30th Sep 2009 4:34pm |
Cheers bud NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
30th Sep 2009 4:38pm |
Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216 |
Hi, my brake vacuum pump begins to lose oil, not too much, but there is a slight halo near the pulley.
My 110 is of January 2009 and it has 33.000 km now, do you think I can require the substitution from LR? Matteo Defender 110 Td4 SE MY 09 |
21st Oct 2009 7:48am |
If its leaking take it to the dealer they will replace it for you NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
21st Oct 2009 8:25am |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 |
so, i am welcoming to the club after 56.000Km. must be a world record or no ?
should i try for replacement ? my def was manufactured at '07, so i suppose it is the first ''edition'' of pump. www.newfoundland.gr |
18th Jul 2014 7:18am |
