![]() | Home > Puma (Tdci) > Puma Reverse Light |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
Yes, I have. I put a 5W Cree LED in mine and the improvement is good. Mine is one of these: http://www.ebay.co.uk/itm/300551786533
Pete |
Thanks for the info,just ordered one ![]() 1968 1/32 scale Britains 109 Pick up. |
It's pretty good Grock. I don't think you'll be disappointed.
Pete |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3663 ![]() ![]() ![]() |
XS Pete
ive ordered one as well DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537 ![]() ![]() ![]() |
My reverse lamp is hooked up to my work light, both lamps light my rear up beautifully!!
![]() BAS re Remap, BAS Turbo, BAS Spec Modified Airbox, Twisted Side exit Decat Exhaust, Allisport Cooler and Hoses, OME Sport Shocks, Kangaroo Paw Discs. 2001 Discovery II Porsche Speedster Replica 1956ish |
i want a rear work light / reversing light WITHOUT putting extra holes in the body....any ideas
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Mag-mount? [you can place a steel plate behind panel] Or suction mount ... both common worklamp fittings ![]() |
Just for info, the reason I particularly went for a USA made Cree LED lamp, was because I bought one of their maglite upgrade kits for one of my 'D' cell maglites and was massively impressed
![]() Pete |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20678 ![]() ![]() |
Bigfog: AFAIK unless your set up includes a switch it's illegal to have rear work lights triggered by selecting reverse gear. Correct me if I'm wrong
![]() TIG: How about magnetec based worklamp? I think D44 do one. Only problem would be: A. theft and B. routing the cable. Maybe routed under rear door seal providing that it doesn't get crushed or damaged! ![]() |
That is correct. So, I suspect, is a more powerful bulb in the existing light. In the grand scheme of things though, there are far worse lighting related crimes on the roads every day that go ignored (fog lights, blue lights, aftermarket HIDs, etc) so I can't see overly bright reversing lights being at the top of anybodys 'to prosecute' list. An isolating switch on a worklight isn't a bad idea though.
Mount it inside one of the small rear windows? To be honest, mounting it externally isn't too much of a problem - use a CB aerial gutter mount. Getting the power to it is the tricky part. You might be able to thread a cable through the door seal, but that seems a bit too Heath Robinson for me. So, short of something powered by induction, you'll need a hole for a cable. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Have a look at a shooting suppliers, I saw a pretty impressive suction mount shooting light on the stand next to mine at the Midland Game fair. Works off a 12v socket and was remote control, don't know how good the mount was but should do the job Id have thought. Supposed to be for spotting bunnies etc but would work just as well as a rear spot. Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
Lightforce do a suction mounted 30watt stubby light, so that is a possibility.
There are various watertight seals for taking wiring through the roof etc. Have just picked up a sample for taking up to 5 cables through roof. If you have a roof rack fitted cabling can be run along rack to front down snorkel and under bonnet or down rear access ladder. Brendan |
Brendan[/quote] Great suggestions! Never thought of the rear ladder myself. |
don't want a rack or a ladder. I'm thinking mounting off the wheel carrier..so it raises above the wheel and shines down.
