Home > Td5 > Sagging Roof Lining
Page 2 of 2 <12
excossack
Mine has gone saggy in the rear section of the roof lining....I think this is due to the windows leaking and the alpine window seal leaking.....(again) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #126511 24th Feb 2012 9:00pm
RRUK
Laurie wrote:
Thought that only happened on Classic Rangies.....
They must have changed the material cos my 90's headlining is a material that will never sag, its a hard finish, not a soft material. It's sort of a wipe clean finish, but padded. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #126530 24th Feb 2012 10:05pm
The Musketeer
United Kingdom 1988 Defender 90 Other HT Cairns Blue
Not original... Good things come to the wild and free
Post #126540 24th Feb 2012 10:25pm
The Musketeer
GREENI wrote:
I had a laselle in one of my old 90's...
No real issues with it at all...
I'd stick with fixing original though...
Can I be a pain and ask about the stereo fitting? is it part of the lining or a din tray type set up/ I would rather not obstruct the vents when i fit one. Good things come to the wild and free
Post #127582 28th Feb 2012 10:25pm
paullo
Canada
It's part of the headlining; you get a stereo mount up top by the rear view mirror, and speaker mounts just above the b-pillar near your head.
http://www.lasalle-trim.co.uk/headlinings
Post #127611 29th Feb 2012 6:12am
pormpaul
2002 Defender 110 Td5 SW Alpine White
Where did you get those, Bunji hold thingies above the drivers and passengers heads
Post #168008 13th Sep 2012 5:59am
alfajock
United Kingdom 1989 Defender 110 V8 Petrol CSW Bonatti Grey
I gave up on regluing mine after a few attempts because it was too badly ripped. My temporary solution was to just pull off the remaining covering material, brush the crumbled foam dust off the moulded substrate, and paint it in-situ. Worked surprisingly well, and you had to look much harder than any sane person looks at a headlining to notice what it was.
Five years later after much mud splashed on it and marks from crap carried in the back, I've just redone it with some of Dulux's finest kitchen and bathroom paint in a very fetching slate grey!
Yes, I know I am a tightwad, but I have a V8 to feed Shocked Fully Restored 89 110 CSW V8
CLS 350 CDI for the sensible stuff
Post #168148 13th Sep 2012 6:10pm
farmer giles
pormpaul - you can get those map pockets from leeds on this forum (4x4 overlander.com) or mudstuff - both excellent companies to deal with Thumbs Up
Post #168303 14th Sep 2012 7:31am
pormpaul
Thanks. They look really handy! Smile Did you screw them straight into the headliner?
Post #168378 14th Sep 2012 1:58pm
farmer giles
you can either use short self tapper screws or you could ease the headlining down and bolt with a spreader washer.
i wouldn't want to carry anything heavy up there for fear of it breaking loose and gravity taking over. But you should be fine down under as you are already upside down Wink
Post #168396 14th Sep 2012 3:30pm
cinstone
England 2015 Defender 90 Puma 2.2 XS CSW Keswick Green
My fix only lasted a couple of months, probably due to the glue I was using, spray latex adhesive. Although it would probably have lasted longer if I'd have used it over a wider area.
What glues do folk suggest?
Chris. http://shropshirelandrovers.freeforums.org
2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW.
Previous LR's: Michael, my 2008 Defender 90 XS SW.
Machinas oportet intrare non capsicum annuum faveo
Post #168697 16th Sep 2012 10:29am
RRUK
If a job's worth doing, it's worth doing right.....
 2016 D4 HSE
Post #168707 16th Sep 2012 12:30pm
Kent_keith
England 2005 Defender 90 Td5 CSW Zambezi Silver
My rear lining was sagging, I fixed the problem by attaching the rear map light backing plate to the roof, there is a metal channel running lengthways just for this purpose (probably) no more sagging Very Happy 2005 TD5 90 CSW XS
Post #413775 4th Apr 2015 4:00pm
Page 2 of 2 <12
