![]() | Home > Td5 > Sagging Roof Lining |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
take it out and re glue it all
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
on my 300 i cut a few very small slits and sprayed in glue. all sorted.
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 ![]() ![]() ![]() |
About 6"from the rear map light towards the rear door you can insert a plastic trim tree once a small hole has been made in the head lining and that will then suport the head lining in the middle, either side i then used a couple of lenghts of valcro 2004 TD5 Defender 90 xs station wagon
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 ![]() ![]() ![]() |
Rear headlining in mine sagged, so I removed the interior light and let it air for a couple of days. Then I used a latex spray adhesive, then lay in the back with my feet pushing the headlining up for about five min's until it stuck.
Then replaced the light. Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 ![]() ![]() |
An OE new is more money than La Salle, and there's will never sag. My front section is tatty and there's none in the rear. Costed up replacement originals and they were far more than La Salle. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
LaSalle
kateb Member Since: 09 Oct 2011 Location: durham Posts: 9 ![]() ![]() |
Thanks very much guys...will try to re-fix but if that doesn't do the trick will probably go for the la salle option
Cheers! ![]() |
richuk Member Since: 13 Nov 2011 Location: Dorset Posts: 201 ![]() ![]() |
I fitted La Salle in my DC Tomb Raider. Excellent fit and no more sagging - ever! I was concerned that it may increase noise from a drum effect, but did not. I did glue foam camping mats to the top side of it first though - to help insulate and reduce potential condensation. In short - would recommend.
![]() semper in excretia sumus solim profundum variat |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
you could try giving equicar a call to see if they have any nearly new headlinings for sale?
The Musketeer Member Since: 07 Feb 2012 Location: United Kingdom Posts: 193 ![]() ![]() ![]() |
I spoke to them last week and they didn't ahve any rear or full headlings for a 90, good call though, I think they have everything I don't want! Good things come to the wild and free |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 ![]() ![]() |
I had a laselle in one of my old 90's...
No real issues with it at all... I'd stick with fixing original though... ![]() |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Ive had my headlining out of my 300tdi for around a year now (due to rebuild) and im amazed at how much condensation collects on the inside of the roof. I assume this just drips down onto the back of the headlining causing it to eventually sag over time?
I have a 90 front section for sale, no sagging. 2016 D4 HSE
Thought that only happened on Classic Rangies.....
