Home > Puma (Tdci) > Engine lift bracket.. GRRRRRR
Page 2 of 4 <1234>
cinstone
England 2015 Defender 90 Puma 2.2 XS CSW Keswick Green
It'll fall off on its own given enough time Laughing.
Chris. http://shropshirelandrovers.freeforums.org
2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW.
Previous LR's: Michael, my 2008 Defender 90 XS SW.
Machinas oportet intrare non capsicum annuum faveo
Post #115413 14th Jan 2012 7:25pm
Zagato
Jimbob wrote:
Mines still attached, had a quick glance earlier looks a right pain in the arse to get to to take it off!
Could be if you don't have a spanner and an arm! Thud Come on Jimbob, 2 bolts.....got to be under 60 seconds!
Post #115523 15th Jan 2012 8:38am
wurzell
hi i read this post about 15 mins ago and it stirred me up to do it just been out there less than 5 mins job now done Bow down , bloody annoyed at myself for not doing it sooner as the hose has been rubbed badly i see it goes in to the bulkhead is it an easy replacement or a royal pita, its going in for a full service all oils replaced in a couple of weeks to my local indy so depending on peoples opinions i may wait for him to do it, if you havent done this take heed i consider myself lucky that this didnt burst the pipe Thumbs Up paul n tash
Post #115537 15th Jan 2012 10:41am
bob neville
Just checked my heater hose by the lifting bracket (still fitted) and it is fine.
The hose on mine is held away from the bracket by a plastic clip that goes round the hose and the other end is clamped around a wiring harness.
However, my turbo heat shield was undone - now fixed Thumbs Up
2013 Defender 90 CSW - sold
Post #115545 15th Jan 2012 11:41am
wurzell
hi bob Very Happy i looked at it a while back and our hose was not touching the bracket either,its held by a plastic clip to a wiring harness which was why i left it but im guessing there is some movement of the engine when driving as it has still chaffed badly Thumbs Up paul n tash
Post #115550 15th Jan 2012 11:50am
bob neville
Thanks Paul Thumbs Up
Just removed mine, not very difficult especially as the bottom bolt was not tightened up, I didn't have to touch it with a spanner Shocked
Post #115552 15th Jan 2012 12:20pm
MD5
2009 Defender 110 Puma 2.4 SW Alpine White
I apologize for such a dumb question, but once the bracket is removed, the bolts can be discarded or they must be reinserted and tightened into the engine ? Embarassed Embarassed Embarassed
Post #115628 15th Jan 2012 5:55pm
Zagato
Tape them to the bracket and hang the bracket up somewhere, somebody will be looking for an engine bracket in 20 years time Wink Confused
Post #115630 15th Jan 2012 5:57pm
MD5
Thanks for your answer!
Post #115693 15th Jan 2012 7:17pm
nikojo
another reason to remove it..........mine ate the f-ing harness and started going into limp mode on certain turns at certain speeds..........could not figure out the problem as it was sporadic.
then were able to reproduce the problem by manually "moving" the harness and there it was.
HATE THE RED BRACKET!! Evil or Very Mad
Post #115813 16th Jan 2012 6:40am
nikojo
Post #115814 16th Jan 2012 6:40am
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Just checked on ours, bracket is still there, but there doesn't appear to be any pipes / wires going anywhere near? It's also tightly bolted up.. Do I still need to remove it?
Alex 110 Tdci Double Cab
Post #115905 16th Jan 2012 1:56pm
ericvv
Same with me. Red engine bracket is there. Nothing comes closer than 3 or 4 cm, so presume no need to remove it. Who knows, one day in the future it might serve its purpose. Whistle Hope not of course... You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #115940 16th Jan 2012 5:57pm
Happyoldgit
For the sake of two minutes with a 10mm spanner or ratchet I think it's worth removing and storing away in the vehicle anyway Rolling Eyes Steve.
http://forums.lr4x4.com
Post #115997 16th Jan 2012 8:11pm
Zagato
Alex
Going by what many others have said the bolts work loose through engine vibration. It just make sense to avoid future problems. The brackets are now taken off during production.
Post #116081 17th Jan 2012 7:08am
Page 2 of 4 <1234>
