Home > Maintenance & Modifications > List of Defender DIY mods
Wernerlouw79
South Africa
Hi,
I tried searching, but could not find anything related...
Is there a thread with a list of all the possible DIY modifications and or hints on the Defender? I am looking at the small upgrades that might make the vehicle more comfortable or last longer. I owned two TD5's and only recently found out about the Cruise control mod which seems to be an easy DIY job... The 99 relay on the wipers is another mod I was not aware of.
It might be usefull for people new to Defenders.
If no such list exists we could start something like that, maybe a someone could put links to those mods on the thread as well...
So this is my list so far.
* 99 relay - intermittent wiper relay upgrade
* TD5 cruise control upgrade
* Puma TdCi - fuel system bleed using a compressor, not the LR tool.
* 2009 Landrover Defender 130 Puma
You might go fast, but I can go anywhere...
Post #107420 14th Dec 2011 1:59pm
MartinK
On the 110's...reinforcing the rear mudflap hangars where they join the body. 30 mins with a bit of aluminium plate, a hacksaw and a 6mm drill...big savings in the long run Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #107430 14th Dec 2011 2:43pm
JWL
It's only a little thing but with carrying passengers in the second row(they're only my boys but I do have to keep them happy Rolling Eyes )but with TD5 station wagons and I've noticed with Puma's the interior light set up is a little on the dire side. There is a light to serve the front by the interior mirror and one in the back but nothing to let the 2nd row passengers see where they're putting their feet Shocked I bought another LR interior light and put it in the headlining in the middle and spliced into the existing wiring to the rear light. Result is all round illumination for all. Even if you do nowt else inside this is worthwhile Thumbs Up
Post #107436 14th Dec 2011 3:12pm
Zagato
I've never needed them but others swear by mud rails to get your seat further back.
http://www.mudstuff.co.uk/MUD_Seat_Rails.shtml
Safari Equip Bumperettes
http://www.safari-equip.co.uk/index.php?page=64
Nakatanenga glovebox & rear door arm to stop it swinging back (others do a door arm also Thumbs Up )
http://www.nakatanenga.de/
As MartinK says rear mudflap support brackets for a 110 to stop the panel from splitting, can be got from Entreq
http://www.entreq.de/?___store=english
2 Cans of ACF-50 to keep your pride and joy from rusting
http://www.ebay.co.uk/itm/ACF-50-Anti-Corr...588f460b2a
£99 Dinitrol rust protection kit for chassis
http://www.rejel.com/rejel-store/productid/9408.aspx
A local window fitter to seal your windows Thumbs Up or this if you want to do it yourself
http://www.frost.co.uk/automotive-windscre...ealer.html
Can't seem to get Dum Dum anymore so this will do instead to do your cappings etc as described in the LR water ingress manual!
Capt Tolleys Creeping Crack Cure...well you do own a Defender Whistle Perfect for smaller cracks/gaps!
http://www.captaintolley.com/
The new TDCi stainless steel Adrenalin 4x4 pedal lock
http://www.defender2.net/forum/topic7162-30.html
These don't seem to be listed anywhere on E-Bay though Confused
Post #107448 14th Dec 2011 5:11pm
farmer giles
when the wipers need changing try the silblades from mudstuff.
if you have the td5 then there is the clutch pedal return spring relocation.
as zag has already mentioned - the rear door stay (power assist) is very helpful
Post #107453 14th Dec 2011 5:25pm
paullo
Canada
To be honest, there's a ton of individual threads on this board that have varying levels of DIY info. Search for something specific and you'll likely find it. If you want something super concise with photos; try BusterBus' DIY section on LandyZone.co.uk. Keep in mind, one person's definition of DIY is hugely different from another's...
It's been discussed having something similar set up here, but has yet to be implemented.
Post #107456 14th Dec 2011 5:45pm
Bobble
Air intake snow cover anyone? Whistle
Post #107459 14th Dec 2011 5:50pm
Wernerlouw79
South Africa
It is interesting to see the different things people see as important. I have no use for a snow cover, and corrosion is no problem where I am.
Paullo I understand and have appreciation for the differing levels of DIY. I find searching for mods difficult if you don't always know what you are looking for. I will checkout landy zone thanks.
Btw. The mud flaps can very nicely be replaced with some scrap three ply conveyor belt. Cut and bolt on. Th bolts will break off before the conveyor tears. Be very carefull with the belt knife though. 2009 Landrover Defender 130 Puma
Post #107479 14th Dec 2011 7:20pm
