![]() | Home > Maintenance & Modifications > List of Defender DIY mods |
On the 110's...reinforcing the rear mudflap hangars where they join the body. 30 mins with a bit of aluminium plate, a hacksaw and a 6mm drill...big savings in the long run
It's only a little thing but with carrying passengers in the second row(they're only my boys but I do have to keep them happy
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 ![]() ![]() |
I've never needed them but others swear by mud rails to get your seat further back.
http://www.mudstuff.co.uk/MUD_Seat_Rails.shtml Safari Equip Bumperettes http://www.safari-equip.co.uk/index.php?page=64 Nakatanenga glovebox & rear door arm to stop it swinging back (others do a door arm also ![]() http://www.nakatanenga.de/ As MartinK says rear mudflap support brackets for a 110 to stop the panel from splitting, can be got from Entreq http://www.entreq.de/?___store=english 2 Cans of ACF-50 to keep your pride and joy from rusting http://www.ebay.co.uk/itm/ACF-50-Anti-Corr...588f460b2a £99 Dinitrol rust protection kit for chassis http://www.rejel.com/rejel-store/productid/9408.aspx A local window fitter to seal your windows ![]() http://www.frost.co.uk/automotive-windscre...ealer.html Can't seem to get Dum Dum anymore so this will do instead to do your cappings etc as described in the LR water ingress manual! Capt Tolleys Creeping Crack Cure...well you do own a Defender ![]() http://www.captaintolley.com/ The new TDCi stainless steel Adrenalin 4x4 pedal lock http://www.defender2.net/forum/topic7162-30.html These don't seem to be listed anywhere on E-Bay though ![]() Last edited by Zagato on 14th Dec 2011 4:53pm. Edited 8 times in total |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
when the wipers need changing try the silblades from mudstuff.
if you have the td5 then there is the clutch pedal return spring relocation. as zag has already mentioned - the rear door stay (power assist) is very helpful |
paullo Member Since: 14 Dec 2010 Location: Just Outside the M25 Posts: 47 ![]() ![]() |
To be honest, there's a ton of individual threads on this board that have varying levels of DIY info. Search for something specific and you'll likely find it. If you want something super concise with photos; try BusterBus' DIY section on LandyZone.co.uk. Keep in mind, one person's definition of DIY is hugely different from another's...
It's been discussed having something similar set up here, but has yet to be implemented. |
Bobble Member Since: 21 Aug 2011 Location: Hampshire Posts: 223 ![]() ![]() |
Air intake snow cover anyone?
Wernerlouw79 Member Since: 03 Dec 2011 Location: The Bush Posts: 5 ![]() ![]() |
It is interesting to see the different things people see as important. I have no use for a snow cover, and corrosion is no problem where I am.
Paullo I understand and have appreciation for the differing levels of DIY. I find searching for mods difficult if you don't always know what you are looking for. I will checkout landy zone thanks. Btw. The mud flaps can very nicely be replaced with some scrap three ply conveyor belt. Cut and bolt on. Th bolts will break off before the conveyor tears. Be very carefull with the belt knife though. 2009 Landrover Defender 130 Puma You might go fast, but I can go anywhere... |
