Home > Puma (Tdci) > tunnel getting hot on long journeys
Tattoobloke
United Kingdom 2012 Defender 110 Puma 2.2 HT Alaska White
Hi all just new to the site had my defender 110 puma for 1 year now. The shaft in the transfer box went last year so had a new Ashcroft uprated one fitted. Have done about 10000 mile now and just wanted to know does the inside of the tunnel get hot on long journeys??
Post #999648 11th Jul 2023 6:25pm
Ianh
For sure It does on the Puma’s 2007 onwards, you will notice the metal parts of the handbrake lever is very hot and the metal seat rails connected to the driver seatbox get very hot on long journeys.
There are a few topics on here about it.
It’s the flow of heat from engine, gearbox and exhaust. If you open the driver window it’s significantly worse as the airflow draws heat upwards across your legs and out the window. If you keep the driver window closed but open the passenger window you will notice the handbrake lever , seat mounts, seat box etc remain at a much lower temperature. Give it a try, it’s another one of those quirky ways to drive a defender Very Happy
Post #999653 11th Jul 2023 6:52pm
Tattoobloke
Hi great thanks for that thought there was something wrong with it.Ok will give that a go
Post #999655 11th Jul 2023 6:56pm
Dinnu
2012 and later 2.2s Euro5 have a dpf and must get hot to regenerate. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #999656 11th Jul 2023 7:00pm
Welshsurferdude
Wales
yep gets bloody hot especially when towing on a hot day
not very enjoyable if AC isn't working!
Im thinking of putting insulation down on the trans tunnel and floor to reflect some of it away 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #999660 11th Jul 2023 7:39pm
jst
Windows shut helps alot. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #999664 11th Jul 2023 7:58pm
Welshsurferdude
Wales
not if the. blower is blowing hot air too on cold Big Cry 2011 Santorini Black USW XS.
Post #999665 11th Jul 2023 8:07pm
Ianh
Have you tried the heater valve spring mod , 4th post down https://www.defender2.net/forum/topic78660...ater+valve
Post #999672 11th Jul 2023 8:50pm
Welshsurferdude
Wales
No but ill look into that now cheers! 2011 Santorini Black USW XS.
Post #999676 11th Jul 2023 9:03pm
Muddybigdog
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Zambezi Silver
I was told that a hot tranny tunnel is the curry warmer optional extra, Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold
D3 - 2.7 S x2 (both Sold)
Freelander 2 HSE - Sold
Freelander 1 - Sold
Disco 2 - Sold
Post #999695 11th Jul 2023 9:53pm
