Home > Maintenance & Modifications > New Door Hinges - Any Experience? |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 490 |
Fitted a few sets of ORM hinge sets great qaulity and fit,we like them because they are close to OEM look but work and last. The grease nipples are rather obvious but could be removed,the sight of them does encourage regular greasing. Only criticism is they only provide two plastic gasket/shims per hinge and they are a different profile to the JLR ones. We had to wait for more to arrive from Germany accompanied with a invoice!
22nd Jun 2023 2:10pm |
ashfordsv Member Since: 13 Mar 2009 Location: Wicklow Posts: 82 |
I have the Croytec hinges fitted for about 10 years and they are still perfect
https://www.croytec.co.uk/product/croytec-door-hinges/ |
23rd Jun 2023 8:24am |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 456 |
Hi,
Thank you, I hadn't considered those, I'll add them to the mix. Anyone else got any real world experience, especially of the EM Trim ones? Cheers |
23rd Jun 2023 8:29am |
the_lincs_landies Member Since: 29 May 2023 Location: Boston, Lincs Posts: 230 |
Although I still have the OEM Hinges, I intend to replace. My preference is the Optimill as they are a "security hinge" and there is no bolt visible on the outside, so you need to get into the car to get the door off.
Exmoor Trim, Offroad Monkeys, and Croytec all seem to have the exterior bolts. |
23rd Jun 2023 8:49am |
Agreed on the Optimill, maybe that is the way to go for that very reason - I'm just not sold on the more glossy finish. Wish they did a matt version, would be more suited to what I am after.
Cheers. |
23rd Jun 2023 8:50am |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
Would appreciate a link to the hinges with grease nipples. Thanks. Peter
23rd Jun 2023 6:38pm |
Here you go Peter, they were the ORM ones.
https://www.offroad-monkeys.com/products/l...er=LR-10-4 Cheers. |
26th Jun 2023 7:52am |
Thanks, might need a mortgage for those!
26th Jun 2023 9:02am |
Most of the billet replacement hinges are a similar price for a set, sadly.
Its an investment to combat a known weak spot really. |
26th Jun 2023 9:11am |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
I have optimal on my 110, they aren't liking the harsh Scottish weather and salty roads too much. If I were to do it again I'd be going with ORM or YRM stainless hinges. 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
27th Jun 2023 6:55am |
edward Member Since: 08 Jan 2023 Location: Lincs Posts: 151 |
I have YRM stainless.. Not black as you want - but my preference was
Something that I’d never have to replace. I guess you could spray them? Ed. |
27th Jun 2023 7:55am |
Standard Defender galvanised door hinges, painted and modified to accept greasing of the hinge pins
Classic look that lasts |
27th Jun 2023 8:10am |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
Mine has stainless hinges just like the YRM items. The front door hinges came from SP4x4 in gloss piano black. The 2nd row set came from PowerfulUK in a brushed satin finish (see pic) which took a few coats of Smooth Hammerite to make them look the same as the fronts. 4 years later the paint has a few chips, but then the front set has some too. Functionally both sets remain perfect. Click image to enlarge |
27th Jun 2023 10:41am |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2654 |
All valid points, I would say that this is an open and shut case M’lud…..
27th Jun 2023 11:47am |
