Home > Puma (Tdci) > Exhaust questions
Siwynne
Exhaust questions
I am now running an empty original down pipe. It looks like a dpf but is just an empty shell. The rest of the exhaust is standard at the minute. I want to get it a little more free flowing and a better note without breaking the bank. Considering most of the silencing is done in the dpf if I now go straight through with off the shelf pipes will it be too loud. Has anybody done this ie og empty dpf ,2.5 in straight pipe replacement centre section, and the readily available 3in rear section or the original rear section with small silencer in.
Post #997498 25th Jun 2023 7:04pm
ickle
I run an empty DPF, straight through stainless centre section and a standard stainless rear silencer.
There is a very slight increase in noise - with a little 'bark' when rev'd up, I would have thought either a 3" rear silencer or no rear silencer would be OK
HTH Keith
Post #997505 25th Jun 2023 8:33pm
DPF or cat?
Post #997509 25th Jun 2023 9:39pm
Siwynne
Both. It’s now just a shell. Essentially straight through.
Post #997518 26th Jun 2023 6:05am
bear100
i have a 2.5" Demand engineering CAT shell and sports silencer, lovely note not to boy racer but tuned sounding plus you get the whooshing sucking in noise when changing gear Very Happy
also recommended to do the air box mod Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #997519 26th Jun 2023 6:26am
Siwynne
That sounds like what I’m looking for. I’ll change the centre section then the rear section if I don’t get the results I’m after
Thanks for the replies
Post #997607 26th Jun 2023 5:29pm
