Home > Puma (Tdci) > removing transfer box
rich585
I have the gearbox and tranferbox out of the vehicle. I've taken 4 bolts and 2 nuts off and the transfer box has moved a little bit, perhaps a mm or two but seems reluctant to go any further. Is there a reason it's not moving?
Is there another fixing somewhere? Can I lever it off? Does it just neeed a load of wiggling?
Cheers!
Post #997341 24th Jun 2023 7:37am
There are only six fasteners holding the two boxes together so, assuming you've removed the correct six of course, they should separate. Wiggling and shaking should do no harm (and if that doesn't help try wiggling and shaking the transfer box!) but avoid brute force. If the really won't come apart, remove the bottom plate from the transfer box and/or the PTO cover and try to see what is snagging.
Post #997347 24th Jun 2023 9:04am
rich585
All six are out, 4 bolts and two stud nuts.
It feels like its still attached at the bottom as the top of the case has opened up a mm or so.
Can't see any more nuts or bolts, but I assume there is a dowel or two in there?[/quote]
Post #997387 24th Jun 2023 4:02pm
Yes, two (as I recall) locating dowels, one at the top and one at the bottom. The top one is coaxial with a fastener.
Post #997398 24th Jun 2023 5:13pm
rich585
Just wondering if it would be easier to tip the whole assembly up on its end and lift the transfer upwards with the engine crane?
Post #997401 24th Jun 2023 5:50pm
NickMc
I think it’s about 35kg, I normally take the handbrake drum off and then the four bolts inside holding the whole assembly off in one and set it on top of the exhaust silencer out of the way with cable etc still attached. Makes it a bit more manageable to work with.
I can lift one on the floor myself easy enough, I guess it depends on how strong and nimble you are.
Are all the levers,connectors and breathers disconnected?
Post #997405 24th Jun 2023 6:27pm
rich585
Quote:
Report post
The whole gearbox and transfer box are out of the vehicle.
Something seems to be keeping it from sliding off.
It's moving, so its not sealant or anything.
Post #997413 24th Jun 2023 8:22pm
rich585
Got it off!
What do I look for to decide if to replace the intermediate shaft?
Post #997450 25th Jun 2023 9:53am
rich585
Splines look OK to me. No slack. Bone dry of course, so I'll put some EP grease in there.
I know the brown dust is worn off metal but there's not much of it.
I did see that there are two splines missing on the cup, opposite each other. Normal?
Post #997452 25th Jun 2023 10:37am
That looks pretty good. I'd clean if thoroughly and reassemble with plenty of molybdenum disulphide grease (CV joint grease) and a new seal.
How many miles has that done?
Post #997457 25th Jun 2023 11:10am
Dinnu
Just a reminder that one of the bolts is shorter otherwise can bind the intermediate gears.
Edit - just a note for when you re assemble. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #997459 25th Jun 2023 11:26am
Ianh
Would Morris K48 molly grease be good in this application https://www.morrislubricantsonline.co.uk/k48-moly-grease.html
Post #997474 25th Jun 2023 3:29pm
rich585
21k miles. not even run in.... except that the clutch slave cylinder expoded...
Post #997476 25th Jun 2023 4:07pm
rich585
Thanks! I'll check that. They are all still in the housing at the moment!
Post #997477 25th Jun 2023 4:08pm
Yes, perfect. Moly grease is ideal for things that slide rather than roll, so in this application is better than traditional lithium based grease.
There are many people who have had them fail at a lower mileage than 21k. Shocked
Post #997487 25th Jun 2023 5:28pm
