![]() | Home > General & Technical (L663) > Back Seat USB Ports Missing |
eakae Member Since: 20 Nov 2022 Location: Birmingham Posts: 7 ![]() ![]() |
Happy to say I've had 3 USB-C sockets fitted by the dealer today. One quick question though are there suppose to be 2 or 4 sockets on the rear centre console? Thanks. |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1449 ![]() ![]() |
I have four blank plates so assume four. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
That was my thinking also...
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1235 ![]() ![]() |
stu-rst Member Since: 01 Jan 2023 Location: derby Posts: 1 ![]() ![]() |
My V8 110 has no USB C's in the rear console just 2 USB A's. Dealer tells me this is correct and the bulletin doesn't apply to mine! Not sure what level of spec warrants getting the 2 USB C's fitted if a V8 isn't high enough!
dshark1 Member Since: 17 Jun 2023 Location: Florida Posts: 20 ![]() ![]() |
Wow, that’s crazy. I would check with another dealer or call Land Rover direct to verify |
martinf Member Since: 30 Nov 2020 Location: Sussex Posts: 103 ![]() ![]() |
My 2022 P300 HSE has two USB-Cs in the two central positions and at either end a 12v power socket. This seems like a logical layout to me.
My 2022 P300 HSE has two USB-Cs in the two central positions and at either end a 12v power socket for the rear seat passengers. This seems like a logical layout to me.
as per my photo above.
dshark, the salesman has lied to you ![]() ![]() |
