Home > Technical > Front brakes hotter than rear is it normal?
Djmdaniel
United Kingdom 2002 Defender 90 Td5 SW Aintree Green
Is it normal for the front brakes to get hotter than the rear on my defender 90 td5 both hot to the touch but front ones seems to be hotter than the rear ones to touch after about 30 min of driving? Thank you
Post #997047 21st Jun 2023 7:13pm
LR90XS2011
vehicles generally brake harder on the front than the rear as weight transfers to the front when braking, hence why in most cases front brakes are bigger than rear brakes, hence wouldn't be surprised that front brakes are hotter DEFENDER 90 TDCI XS,
Post #997048 21st Jun 2023 7:15pm
Retroanaconda
Yes. The fronts do the vast majority of the work
Post #997049 21st Jun 2023 7:15pm
Djmdaniel
Thank you
Post #997052 21st Jun 2023 7:20pm
Djmdaniel
thank you
Post #997053 21st Jun 2023 7:20pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Re: Front brakes hotter than rear is it normal?
Sounds normal and it’s best to let them cool for 10mins before you touch them. Do you have an issue that has made you ask this specific question Question Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #997058 21st Jun 2023 8:23pm
Curiously on my Puma 110 after any significant run the rear hubs are warm to the touch but the fronts have no discernible warmth at all. I've never really understood why. There is no significant weight difference between the axles (around 200lbs), brakes and wheel bearings are all good, and it has always been like this. I can only conclude that the fronts dissipate heat better than the rears.
Post #997083 22nd Jun 2023 6:36am
