Home > Puma (Tdci) > Clutch slave cylinder leak. Gearbox out!
rich585
My 2009 20k mile puma clutch slave cylinder has decided to leak...
I'm in the process of getting the gearbox out to fix it.
Any tips on getting the downpipe and cat out? Seems that the chassis rail is in the way?
Any other tricky bits, I will run into?
Cheers!
Post #996585 17th Jun 2023 8:26am
MK
If you have front antiroll bars, remove it and you should be able to make some twists to remove the can. I remember it was a bit of a pig. Puma 110" SW
Post #996638 17th Jun 2023 4:50pm
rich585
OK, I'll look at taking the front ARB off. So the downpipe may need to be rotated a lot to get the cat out?
Post #996642 17th Jun 2023 5:48pm
NickMc
Order a spigot bearing and change it.
Post #996645 17th Jun 2023 6:07pm
MK
yes, rotated.
Try to get the LOF kit that comes with a better quality friction plate and bearing/slave cylinder. Puma 110" SW
Post #996672 17th Jun 2023 9:58pm
rich585
Quote:
yes, rotated.
Yes, already spoken to LOF about their kits. Will look at replacing the intermediate shaft too.
Post #996683 17th Jun 2023 10:55pm
rich585
Got the CAT out. I took off the lower heat shield and it pretty much came straight out after rotating about 90 degrees.
Didn't need to take off the ARB.
Next issue is the mid silencer box flange nuts, or rather rusty nubs... oh joy...
Post #996738 18th Jun 2023 12:58pm
MK
If you plan to remove the spigot bearing, try to get the ad-hoc tool. Otherwise is painful to remove it. Puma 110" SW
Post #996742 18th Jun 2023 1:54pm
Don't forget to inspect and lubricate the infamous output adaptor shaft coupling.
Post #996751 18th Jun 2023 3:16pm
rich585
I guess the bread/grease trick doesn't work with Puma spigot bearings then?
Post #996753 18th Jun 2023 3:25pm
MK
It works. Or you may need a small and sharp chisel to break the bearing apart. Puma 110" SW
Post #996755 18th Jun 2023 3:34pm
rich585
I'm thinking of swapping it out for a LOF one piece part.
Post #996814 19th Jun 2023 7:55am
