![]() | Home > Puma (Tdci) > Clutch slave cylinder leak. Gearbox out! |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2450 ![]() ![]() ![]() |
If you have front antiroll bars, remove it and you should be able to make some twists to remove the can. I remember it was a bit of a pig. Puma 110" SW
rich585 Member Since: 30 Sep 2020 Location: dorset UK Posts: 18 ![]() ![]() |
OK, I'll look at taking the front ARB off. So the downpipe may need to be rotated a lot to get the cat out?
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1678 ![]() ![]() ![]() |
Order a spigot bearing and change it.
yes, rotated. Try to get the LOF kit that comes with a better quality friction plate and bearing/slave cylinder. Puma 110" SW ............................................................. Earth first. Other planets later |
Yes, already spoken to LOF about their kits. Will look at replacing the intermediate shaft too. |
Got the CAT out. I took off the lower heat shield and it pretty much came straight out after rotating about 90 degrees.
Didn't need to take off the ARB. Next issue is the mid silencer box flange nuts, or rather rusty nubs... oh joy... |
If you plan to remove the spigot bearing, try to get the ad-hoc tool. Otherwise is painful to remove it. Puma 110" SW
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
Don't forget to inspect and lubricate the infamous output adaptor shaft coupling.
I guess the bread/grease trick doesn't work with Puma spigot bearings then?
It works. Or you may need a small and sharp chisel to break the bearing apart. Puma 110" SW
I'm thinking of swapping it out for a LOF one piece part. |
