Home > Off Topic > Parking - I feel I need a moan. |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5165 |
I got you beat Click image to enlarge Click image to enlarge Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
7th Jun 2023 7:54pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4655 |
Yes height restrictions are a nuisance. Even if the bar is high enough (just about) if they tar the surface they do not raise the bar.
Saw a sign at a hotel under ground car park saying 6ft 6 inches clearance. Great you say. Just went into check and after the entrance slope there was some air conditioning trunking suspended from the ceiling which brought the clearance to wrist level when I reached up to it. Always check!!! 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
8th Jun 2023 10:30am |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2634 |
In Truro there is a multi-storey that on the ground floor the bays are clearly marked ‘Land Rover’……and yep you guessed it, mostly filled up with normal cars because their owners can’t be bothered to walk.
8th Jun 2023 10:46am |
