Home > Maintenance & Modifications > What can I expect going from 1.667 to 1.410 in a t-box?
Mini Landie
United Kingdom 2003 Defender 90 Td5 HT Belize Green
I have had this super annoying clunk going on for years that I've spent a fair amount of time & money trying to locate.
I've long been looking at getting an Ashcroft t-box in 1.410 ratio, but looking at my current t-box, it's labelled up as 1.667. From my research, this seems to be more of a 110 ratio but mine is a 90 (hardtop). This seems odd to me but hey, Defenders are essentially big Meccano sets after all so it's not impossible.
My use case is about 30 motorway miles a day and a bit of laning, and the odd pay & play site. I'm also a member of my local 4x4 response group, so recoveries are entirely possible.
It seems 1.410 was a standard Defender ratio. I'm sure it's a bit of a silly question but what can I expect out of the 1.410, which will save me an extra £100 outlay? 2003 90 TD5 Hardtop
Post #994888 2nd Jun 2023 5:37pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Odds are that your transferbox is actually 1.410 and not 1.667. For some reason, a number of them had the incorrect sticker put on the casing.
My old box was a 1.410 marked as a 1.667.
The serial number will tell you exactly what you have. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #994890 2nd Jun 2023 6:23pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
1.6 is a bit of a rarity just for early 110s. I have a standard tdi 110 on a 1.4 T-box and running slightly bigger tyres (33") and don't find myself struggling for gearing when pulling away on a steep hill or flat out (85mph+) on the motorway. If it were my choice, I would go 1.4 all day long. Many people go 1.2 ratio but on paper, and I guess in practice, this will take the edge off acceleration and risks being a bit gutless when flat out with needing to drop into 4th more frequently when facing any inclines?
Post #994928 2nd Jun 2023 11:39pm
Dinnu
Were the 1.667 ratio used on the 2.5 normally aspirated engines (12J). They would have needed the lower ratio due the lower engine torque especially with a heavy 110. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #994933 3rd Jun 2023 4:08am
Mini Landie
Thank you all so much for the info. It's really been bugging me. I'll take a note of that serial number and I'll definitely make sure I add the 1.410 to my basket!
Makes me laugh that 1.410s were labelled up as 1.667!
I have thought about the 1.2 but I'd like to retain its Defenderness, even at the expense of fuel consumption. 2003 90 TD5 Hardtop
Post #994942 3rd Jun 2023 7:38am
Linds Hanson
90 TD5's will easily pull 1.2 gearing and a V8 5th gear makes them much nicer on the motorway, never heard of 1.6 stickers on wrong transfer box? in 45 years of professional Land Rover repair
Post #994956 3rd Jun 2023 11:40am
Mini Landie
Box is stamped 13D, and according to the LT230 info on this page - http://www.red90.ca/rovers/gears.html - that makes it a 1.667.
Dealer who sold it to me said he thinks it's been mapped. In my 4 years with it, I have to disagree. It being 1.667 is probably where that idea comes from.
Edit: best photo I managed to take of it.
Edit #2: Nope, I think I’m being a tit? Looks like 43D? Which is 1.410?
Details in the technical section - https://ashcroft-transmissions.co.uk/product/lt-230/
It was really hard to see properly but I noted the serial number down as H13D014986G. That H was probably a 4. 2003 90 TD5 Hardtop
Post #994957 3rd Jun 2023 12:07pm
landy andy
When I had a Td5 90 that had a T box labelled as 1.6. But if it was a 1.6 box I would have had a lot lower top end speed and much more revs/noise. You wouldn’t want to do motorway with a 1.6 box.
Post #994963 3rd Jun 2023 1:24pm
Mini Landie
I tend to travel along at 60 on motorways. I can hit 80 but it is screaming its arse off there, and 70 is just a bit too loud to cruise along at.
I don't know what it's like driving a standard Def other than my own. It's either been a beast of a 90 200TDi, or a mapped 110 TD5. 2003 90 TD5 Hardtop
Post #994965 3rd Jun 2023 1:38pm
landy andy
Sounds the same as my Td5 110 which has standard gears. Thumbs Up
Post #994966 3rd Jun 2023 2:02pm
TexasRover
Yep same on my Td5 110. 80 kph (50 mph) is perfectly fine, 90 kph (55mph) is getting noisier, 100kph (60mph) is getting annoyingly noisy quickly. Any faster is basically hearing protection required. Standard 1.4 transfer case
I just pulled the trigger on a roamerdrive which should cut back on the noise significantly
Post #994970 3rd Jun 2023 3:33pm
ashtrans
Site Sponsor
thats a 43D, not 13D, the 13D is a good number but was stamped in a diferent place and stamped as opposed to the 43D witch is dot punched, both are 1.410 ratio,
the 90's never had the 1.667, only 2.5 N/A 110's
note the early 2.5 N/S 110 1.667's were stamped 12D Dave
Post #995506 7th Jun 2023 8:16pm
ashtrans
Site Sponsor
this was simply a sticker error on early TD5's, they were stamped 43D, were 1.410 ratio but had 1.667 stickers in error !! Dave
Post #995507 7th Jun 2023 8:17pm
Mini Landie
Jolly good to hear from the man himself. Thank you for the knowledge and wisdom.
Expect an order from me in a couple of weeks! 2003 90 TD5 Hardtop
Post #995511 7th Jun 2023 8:25pm
Chicken Drumstick
Generally yes, but only LWB I think and most of them being MoD vehicles.
The 1.6 was also used with the BMW 2.8 six pot in the S African 90 and I suspect may have been used in the Italian Army 2.0 MPI 90's too, but would need to check up on the latter.
Post #995571 8th Jun 2023 12:28pm
