Home > Maintenance & Modifications > What can I expect going from 1.667 to 1.410 in a t-box? |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 896 |
Odds are that your transferbox is actually 1.410 and not 1.667. For some reason, a number of them had the incorrect sticker put on the casing.
My old box was a 1.410 marked as a 1.667. The serial number will tell you exactly what you have. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
2nd Jun 2023 6:23pm |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 808 |
1.6 is a bit of a rarity just for early 110s. I have a standard tdi 110 on a 1.4 T-box and running slightly bigger tyres (33") and don't find myself struggling for gearing when pulling away on a steep hill or flat out (85mph+) on the motorway. If it were my choice, I would go 1.4 all day long. Many people go 1.2 ratio but on paper, and I guess in practice, this will take the edge off acceleration and risks being a bit gutless when flat out with needing to drop into 4th more frequently when facing any inclines?
2nd Jun 2023 11:39pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
Were the 1.667 ratio used on the 2.5 normally aspirated engines (12J). They would have needed the lower ratio due the lower engine torque especially with a heavy 110. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
3rd Jun 2023 4:08am |
Mini Landie Member Since: 23 Sep 2015 Location: Basingstoke Massiff Posts: 159 |
Thank you all so much for the info. It's really been bugging me. I'll take a note of that serial number and I'll definitely make sure I add the 1.410 to my basket!
Makes me laugh that 1.410s were labelled up as 1.667! I have thought about the 1.2 but I'd like to retain its Defenderness, even at the expense of fuel consumption. 2003 90 TD5 Hardtop |
3rd Jun 2023 7:38am |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 485 |
90 TD5's will easily pull 1.2 gearing and a V8 5th gear makes them much nicer on the motorway, never heard of 1.6 stickers on wrong transfer box? in 45 years of professional Land Rover repair
3rd Jun 2023 11:40am |
Box is stamped 13D, and according to the LT230 info on this page - http://www.red90.ca/rovers/gears.html - that makes it a 1.667.
Dealer who sold it to me said he thinks it's been mapped. In my 4 years with it, I have to disagree. It being 1.667 is probably where that idea comes from. Edit: best photo I managed to take of it. Click image to enlarge Edit #2: Nope, I think I’m being a tit? Looks like 43D? Which is 1.410? Details in the technical section - https://ashcroft-transmissions.co.uk/product/lt-230/ It was really hard to see properly but I noted the serial number down as H13D014986G. That H was probably a 4. 2003 90 TD5 Hardtop |
3rd Jun 2023 12:07pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5695 |
When I had a Td5 90 that had a T box labelled as 1.6. But if it was a 1.6 box I would have had a lot lower top end speed and much more revs/noise. You wouldn’t want to do motorway with a 1.6 box.
3rd Jun 2023 1:24pm |
I tend to travel along at 60 on motorways. I can hit 80 but it is screaming its arse off there, and 70 is just a bit too loud to cruise along at.
I don't know what it's like driving a standard Def other than my own. It's either been a beast of a 90 200TDi, or a mapped 110 TD5. 2003 90 TD5 Hardtop |
3rd Jun 2023 1:38pm |
Sounds the same as my Td5 110 which has standard gears.
3rd Jun 2023 2:02pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1048 |
Yep same on my Td5 110. 80 kph (50 mph) is perfectly fine, 90 kph (55mph) is getting noisier, 100kph (60mph) is getting annoyingly noisy quickly. Any faster is basically hearing protection required. Standard 1.4 transfer case
I just pulled the trigger on a roamerdrive which should cut back on the noise significantly |
3rd Jun 2023 3:33pm |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 257 |
thats a 43D, not 13D, the 13D is a good number but was stamped in a diferent place and stamped as opposed to the 43D witch is dot punched, both are 1.410 ratio, the 90's never had the 1.667, only 2.5 N/A 110's note the early 2.5 N/S 110 1.667's were stamped 12D Dave |
7th Jun 2023 8:16pm |
this was simply a sticker error on early TD5's, they were stamped 43D, were 1.410 ratio but had 1.667 stickers in error !! Dave |
7th Jun 2023 8:17pm |
Jolly good to hear from the man himself. Thank you for the knowledge and wisdom.
Expect an order from me in a couple of weeks! 2003 90 TD5 Hardtop |
7th Jun 2023 8:25pm |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 718 |
Generally yes, but only LWB I think and most of them being MoD vehicles. The 1.6 was also used with the BMW 2.8 six pot in the S African 90 and I suspect may have been used in the Italian Army 2.0 MPI 90's too, but would need to check up on the latter. |
8th Jun 2023 12:28pm |
