Home > In Car Electronics > Aftermarket Amplifier In Standard Sound System - Help
widger
Australia
Hi guys,
I am trying to figure out how to wire in an aftermarket amplifier into a D90 2023. I couldnt get the meridian sound, so I have standard sound, and aware of the location of the factory amp, but figure out line input wiring is proving to be so painful. Does anyone have any advice on this, I have found some wiring diagrams but since have not made any sense to them as I have no sub and alot of them refer to having sub wiring output from amp, but its the inputs I am struggling to figure out!!!!!!!
Aaron
Post #992532 14th May 2023 1:59am
Furball
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Hi Aaron, just to clarify, you want to install an amp and keep the standard speakers?
Post #992986 17th May 2023 2:35pm
widger
Australia
Hi mate,
Yes! I then will upgrade the speakers and sound deaden at a later date.
Thanks
Aaron.
Post #992987 17th May 2023 2:39pm
Furball
Its relatively easy. You need to make a decision on what spec speakers, then this will determine your amp or vice versa. They need to be ‘power matched’. If you need more info on this, then let me know. Do you have a spec in mind?
You can buy amps with both RCA connector inputs from your head unit, or take the speaker output from you system. If you are really struggling with your wiring, then i would go the latter route and use the speaker output and connect these to the amp then on to your new speakers.
Potential issues;
Baring in mind its a 2023 Defender and i assume having a invaluable warranty, i would be careful not to cut the wiring and use proper connectors. It may be worth seeking professional help as if you pay an approved audio centre, you will have recourse if it goes t1ts up.
Post #993013 17th May 2023 5:06pm
