Home > Puma (Tdci) > Help - reversing switch on Puma 2.4? |
AndyTunn Member Since: 10 Jan 2015 Location: Auckland Posts: 313 |
I had to replace my gearbox switch and got at it via the access panel under the cubby box - a bit tight but doable. This is what the switch looks like when you get there...
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
29th Jul 2015 8:38am |
HK07 Member Since: 15 Dec 2016 Location: Hampshire Posts: 746 |
Did mine tonight ready for its MOT, as reversing lights are now part of the test.
Took out the cubby box and blanking plate, but to tight for me to swing the spanner in there. Took out the plastic transmission tunnel and Bob's your uncle - there it is looking at you. Thanks for all the advice from here. HK07 2007 90 Puma - Love it - Best car I have ever owned. 1989 Ninety 200tdi - Love it - Second best car I have ever owned. 1951 80" Series 1 - Love it - Third best car I have ever owned. |
26th Jun 2018 7:03pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8044 |
Does anyone know where I could get a female plug to connect to the mt82 gearbox reverse light selector switch please? Ideally with flying leads.
Click image to enlarge Click image to enlarge Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
23rd Mar 2023 1:49pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6608 |
PM replied to 1988 90 Td5 NAS soft top
2015 D90 XS SW |
23rd Mar 2023 1:53pm |
Solihull Boy Member Since: 02 Oct 2012 Location: YORKSHIRE Posts: 68 |
Had to replace my defective switch, it's quite easy, I did it from inside by slackening all the bolts holding the transmission tunnel, this gives you enough movement to remove what's necessary, but you require a very short spanner to do the job Retired from the day job and now self employed - what a life!!
26th Mar 2023 5:43pm |
