Home > Puma (Tdci) > Help - reversing switch on Puma 2.4?
ZeDefender
Quick search but no luck...
Please can someone tell me if the reversing light switch is easily accessible/removable/serviceable on the Puma 2.4 (MT82) with basic tools? Any pics even better. My reversing/trailer light and camera are all dead. Fuse is fine. I'm on holiday and don't want to jack up/crawl around underneath unnecessarily Whistle
Many thanks for any help you can give.
Matt Tell someone you love them today because life is short.
Post #440943 28th Jul 2015 10:54am
Not really (and it's also very difficult to photograph unless you remove the transmission from the vehicle).
It is very inaccessible from underneath due to the proximity to the transmission tunnel in the floor. The easiest way to access it, without too much dismantling, is to remove the seat box centre panel from between the two front seats and reach in from there. The switch is located towards the top of the left (when facing forwards) side of the gearbox. Mine was loose from the factory with the result that the lights were intermittent - I though thte switch was faulty but in practice it simply needed tightening up.
Post #440959 28th Jul 2015 11:27am
Lorryman100
Post #440962 28th Jul 2015 11:35am
Matt - Check the rear earthing strap, clean it and re-tighten its on the transfer box and easily accessible and visible from underneath.
At least rule that out as an issue first and see if it solves it, if not then it could well be the switch.
Post #440986 28th Jul 2015 12:29pm
ZeDefender
Brilliant - thanks guys Bow down
I'll have a look at the strap and if it's okay I suppose I'll have to wait until next week to check the switch. I'll just get my son to get out and warn others when I'm reversing Wink
Have a good day!
Post #440988 28th Jul 2015 12:38pm
If it is a fault with the earth strap it is likely that you won't have any working rear lights (or rear wiper, if you have one).
Reversing lights are curious things! There is, of course, no legal requirement for them whatsoever (at least in the UK) and their purpose is to illuminate the area into which you are reversing, not to indicate that you are reversing. I once had a loony woman driver get quite abusive because I was reversing my S1 (which has a reversing light operated by a switch on the dash) in daytime, so without the reversing light. I was nowhere near her, but she still taught me some new words because my reversing light wasn't energised whilst I was travelling backwards.
You could, as a temporary measure, swap the lenses over between the (completely useless) rear fog and the reverse lights and simply turn on the rear fog when you reverse, I suppose.
Post #441040 28th Jul 2015 2:30pm
What lights are we talking about here incandescent regular bulbs or LED's?
Post #441043 28th Jul 2015 2:37pm
landy andy
Changed my reverse switch from underneath, only took a few mins, but you do need the correct spanner to fit in the gap.
Post #441045 28th Jul 2015 2:40pm
ZeDefender
Good idea switching the lenses - I might try that to avoid annoying the locals (the roads are really narrow round here and I often block the road).
However, I had to hammer over some really bad ground today (lost a few fillings and the wife was seriously peed off) and it seem to have freed something up - somehow it's working again (for now). I guess it's the switch so I'll see how it goes.
I'll try from underneath when I get back. If not, then from below the cubby (but I fear the carpets may make that awkward).
Cheers all Bow down
Post #441138 28th Jul 2015 7:38pm
munch90
I changed mine from underneath not difficult just tricky to get spanner on
Post #441146 28th Jul 2015 7:56pm
If you want easy acess the matting or carpet needs to come out, the front section only.
Lift rubber gaiter lip up under gearstick and transfer box stick.
UN-clip gearstick and extract.
Slip rubber gaiter off the transfer stick and it's off out the way.
Undo all the bolts on the plastic inspection cover there are a fair few.
Remove plastic cover and bobs your uncle it is there in front of you.
Might be worth it rather than struggling with poor access, but up to you.
Thumbs Up
Post #441188 28th Jul 2015 9:55pm
On my 2007 the carpet on the seatbox has a join along the middle so the two sides can be folded back and tucked under the seats. The centre panel can then be removed easily. Cubby has to come out first of course.
Post #441204 28th Jul 2015 10:49pm
BW - Yep, mine is the same only rubber matting.
I'm suggesting the section in front not touching the seatbox area or under cubby access plate.
Following my method above you can get access leaving cubby and access plate in-situ.
This is of course unless carpeted Defenders need more removal.
In a rubber matted defender the matting is in three separate parts.
1 over seatboxes only
2 over gearbox tunnel and bottom footwells
3 against footwell bulkhead behind matting retainers and directly under dash.
2 should come out in one piece, unless if like I have you have SS sills which you'd have to loosen first.
Had it all apart a month ago or so should have taken pics.
Post #441216 28th Jul 2015 11:20pm
Following on from above to avoid a super long post...
Look at Lorryman100's pic above, you'll see the orange parts these are the holes for the screws that hold down the plastic gearbox tunnel section.
There are more on the seatbox side too, remove all those and the whole plastic cover removes and instant access.
The annoyance is the carpet or matting first.
Another shot from another member here:
You can see the fixings and the section I mean.
Post #441220 28th Jul 2015 11:24pm
The centre part of the carpet (over the tunnel) is also a seperate piece and it isn't difficult to remove. Removing the tunnel cover (as C90 Steve suggests) will give much better access to the switch but is, IMHO, significantly more work than taking out the centre plate from the seatbox.
Both are more work than accessing the switch from underneath, of course!
I guess it largely depends on personaly choice and possibly how big your hands are!
I know that I really couldn't get at mine at all from underneath, certainly not enough to get a spanner on it.
Post #441270 29th Jul 2015 8:46am
